Time for a good idea bad idea
Old Jun 13, 2006 | 12:39 AM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
So my car runs like ***......well, not that bad but it leaks about 4 liters of oil every 3 weeks, it has a small tick coming from it, and my header gaskets leak.... now heres a question
My NOS kit came with 100, 125, and 150 shot....but im buying a 50 shot....
do you think i could safely run the 50 shot without my engine taking a ****?
thanks
Old Jun 13, 2006 | 01:43 AM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
personally i think i'd sell the nos kit to cover gaskets to fix all your leaks. HTat's just my opinion.
Old Jun 13, 2006 | 01:46 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
you will see more gains fixing what is wrong with it then you will by putting a 50 shot onto it. you won't get 50 HP fixing that stuff, but with it broken you won't get 50 HP out of your 50 shot ether.
just
Old Jun 13, 2006 | 10:30 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Just throw the 150 shot on there and finish the engine off, just kidding yeah fix that oil leak before your worried about using nitrous.
Old Jun 13, 2006 | 11:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You're in luck! I have a brand new in box set of header gaskets.
Straight across trade for the NOS kit?
If your headers leak, that's probably your ticking.
Leaking oil, probably won't be changed by using nitrous. I'm thinking like a valve cover gasket, more cylinder pressure won't effect that. Find your leak, if you can, and fix that.
Throw on the 100hp shot, you've got a bike to keep you moving (and much faster too!)
hmm, car running poorly eh? good time to race me then
(actually i've got to hurry and tweak my carb more, it's running more poorly then I first thought...)
Old Jun 13, 2006 | 11:35 PM
Car: 1987 Z28
lol sonix i dunno about that trade I'll get back to you on that one.......
i got brand new header gaskets, but im to lazy to put them in i guess no nitrous for now
Old Jun 13, 2006 | 11:39 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yeah, you have to fix that oil leak first. I know the pretty rainbows your car makes after a rain storm will be missed. But the tap water will taste much better and you won't see dead animals around your car from tasting the fluids.
The exhaust leak needs to be fixed so that the O2 sensor can be used to adjust the nitrous system after you install it.
Old Jun 13, 2006 | 11:42 PM
Car: 1987 Z28
me = no 02 sensor......its an 87 but its carbbed....came that way, with a 305....but got outta that business fast and i have a holley street avenger on it...... which also means no 02 sensor
Old Jun 14, 2006 | 09:04 AM
high c's Avatar
Car: 86 iroc
Engine: yea it has one
Transmission: yea it has one of them also (im 2 for 2) :)
did you have that blue camaro on ebay? (its cool ill do it to my self )
86IROC112
Apr 9, 2016 10:20 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
86Base
Aug 8, 2015 01:34 PM
