looking to get some power out of my 305
Old Jul 11, 2006 | 10:31 PM
toms86Z28's Avatar
ok i have an 86' z28 tpi. 305 i want to get some decent power out of it can anyone help me? as of right now i have comp cam part number cs xe256h-10 wih a .447 intake lift and a .454 exhaust. with comp cam spring number 981-16. 1417-16 rocker arm 1.5. 7812-16 pushrods 5/16" flat tappet. edlbrock headers with a full 3' exhaust. fuel press. regulater set at 50p.s.i. but a code keeps coming up saying lean exhaust. im using stock injectors. with under drive pullys and a air foil. and before and of these mods with jst the cat back i ran 60' 2.033. 330' 6.232. 660' 9.743. 1000' 12.796 1/4 et was a 15.383 at 87.06 on street tires. with no mode except the cat back
Old Jul 12, 2006 | 09:34 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
intake manifold, heads, rear end.
Old Jul 12, 2006 | 09:37 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
put in a 4" bore kit.
Old Jul 12, 2006 | 05:08 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Axle/Gears: 9 bolt 4.11
I like them 4.030" bore kits better......lol
Old Jul 12, 2006 | 10:16 PM
toms86Z28's Avatar
so what gears should i use i was thing 3.73's. what would i have to do to run in the 12's
Old Jul 12, 2006 | 10:31 PM
mw66nova's Avatar
Engine: 7.0L
spend about $8000 and do tons of research if you want to do it n/a, or, put a nitrous kit on it and spray till she blows.
Old Jul 13, 2006 | 05:09 PM
Steven89Iroc's Avatar
https://www.thirdgen.org/forums/prob...ers-forum.html
...Nitrous would be the easiest, cheapest way.
Old Jul 13, 2006 | 09:37 PM
toms86Z28's Avatar
nitrous would be fun. but has anybody heard of blue print engines? JEGS High Performance - Blueprint Engines 383ci SB-Chevy 405HP / 440TQ
and should i still use my fuel injuction or carb? thanks
Old Jul 13, 2006 | 11:47 PM
mw66nova's Avatar
Engine: 7.0L
those numbers were achieved with a 750 cfm double pumper, open headers and no accessories on the front of the motor. and it's not a 305...
what is the goal here? easy, fast combination or wanting to learn how things work and what makes things go fast?
Old Jul 14, 2006 | 02:40 PM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Ive looked into them....pretty sweet deal really w/ a 2 yr warranty and the TPI can go on it without voiding the warranty.....I thought of a blueprint 355 w/spray in a Triumph TR6......
Old Jul 14, 2006 | 08:28 PM
toms86Z28's Avatar
well i want to go fast without spending alot of money. or how about JEGS High Performance - Blueprint Engines SB-Chevy Short Block Assemblies with may be Edelbrock Small Block Chevy Victor Jr. Cylinder Heads with a comp cam setup?
Old Jul 15, 2006 | 10:30 AM
Again...
Nitrous is the cheapest way to use a POWER ADDER on your car. Here in the POWER ADDERS forum, there are lots of people who can answer your Nitrous related questions.
Old Jul 16, 2006 | 11:17 PM
toms86Z28's Avatar
im not looking to use nitrous. what im ment by not spending alot of money was on the 305 i was wounder about the blue print engine. couse it only like $3,000
Old Jul 16, 2006 | 11:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're in the wrong forum. Power Adders are nitrous, superchargers, and turbochargers. If you want to stay with regular air, you need to search in the TPI forum.
Spending $3000 on a 305 engine is a waste.
Old Jul 17, 2006 | 11:21 PM
toms86Z28's Avatar
not for the 305. $3000 for the 383
Old Aug 19, 2006 | 11:37 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i wanna make my 305 more faster like u did, i already put intake and headers on with straight pipe to glasspaks, new timing chain , and removed all the a/c and smog stuff, what else is ther to do to make my 305 fly like urs?
Old Aug 21, 2006 | 02:08 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
DUDE THIS IS FOR n2O , TURBO'S AND SUPERCHRGERS. Try the general tech board. if you aren't gonig to add one fo them go to the other forum ...
Old Aug 21, 2006 | 11:46 PM
Engine: 355
if i wanted ur opinion i would asked u!
Old Aug 22, 2006 | 10:12 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
Dude, I have a 305, it pulls like no other I spent about $3000 to turbo it w/ many supporting mods. I'll get some dyno number soon...but I bet Im close to 325rwhp...with a 305.
Old Aug 22, 2006 | 11:08 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
LOL dont tell Willie that!
Old Aug 22, 2006 | 06:19 PM
Drac0nic's Avatar
Maybe they should change the section title from "power adder" to keep the riff-raff out. Then again, I'd better be quiet they did let me in.
Old Aug 22, 2006 | 09:59 PM
toms86Z28's Avatar
where can i get a tubro for my car
Old Aug 23, 2006 | 06:45 AM
Ol'Blue's Avatar
Car: 1987 Trans Am
Engine: 383
Transmission: TH400
The first thing to do is research!!! there is some good info on this site, and Search the Web homework homework homework!!!!
A good turbo header ias made by BBSDesigns. in this thread here
https://www.thirdgen.org/forums/powe...kit-maker.html
jhawkeye
May 25, 2022 06:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
Brcharrelson
Aug 26, 2015 07:47 PM
