boost+ head gaskets
boost+ head gaskets
heh i managed to blow out a or both head gaskets after just over 2k miles.falure ocured on my 4th 19psi run.if i switch to copper gaskets do i need to get the heads/block o-ringed. or would i be fine just droping a set on the motor as it is.or should i just get a good replacement stock head gasket set and see what happens again.
though im still not sure if i hurt anything else yet.i wont know till i get the motor apart.but im pretty sure its just a head gasket since its blowing antifreeze out the ex
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
Personally I'd get a set of felpro stock replacment gaskets with arp head bolts and try again paying closer attention to your tune. With a good tune most headgaskets will live, last season I put 220 passes on my car running between 19-26psi of boost without a failure. Took the heads off over the winter to replace worn guides and the gaskets looked like new.
If you want a stronger gasket than that try an multi layer steel gasket(like cometic).
HTH,
Steve
HTH,
Steve
HTH,
Steve
HTH,
Steve
Fel-Pro Performance Head Gaskets: FPP-17030 - summitracing.com
That was suggested by Summit's Tech Support.
Car: 2013 C63C
Engine: M156 (P31)
I hope I didnt offend you but I've seen alot of good tunes burn headgaskets, pistons, ect.
Felpro 512SD Perma Torque Severe Duty are similar to what I use(only mine dont carry the severe duty tag)and with arp bolts should be just fine.
I've never personally used MLS gaskets but have heard they work from other people, I personally think the perma torque type gaskets will live in most applications. Though the factory has been using MLS gaskets lately with good results.
Originally Posted by vwdave
Ive heard bad things about MLS gaskets.
Car: 89 camaro rs
Engine: intercooled f1r procharged 383
Transmission: turbo 400
i'd look into cometics. i know guys with em on every type of forced induction possible and they hold up great. a little expensive but definately worth it.
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
I ran them with no problems on about 14-15 psi. Trending Topics
Car: 89 Turbo Trans Am
Engine: 3.8 with a small turbo
Transmission: PTS 2004R
Axle/Gears: 9 " Moser 31 splines 3.50 for now
The headgaskets are a fuse . I would rather blow a headgasket that burn piston and mess up the internals. RJC and cometic make really good headgaskets ....... the problem is im sure you will need a rebuild after you blow their gaskets
here is a link to the cometic site Cometic Gasket, Inc..
Its all about the tune. Ive ran my grand national @ 27psi everytime i drive the car for the last 3yrs no problems on stock headgaskets.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
You need o-rings for copper headgaskets. Either the block or heads. I have my block 0-ringed, and i havent had one problem with my car. 3 yrs of running. And i've had a few misshaps where my wastegate vacuum hose blew off and the engine saw upwards of 30lbs of boost before i noticed. Your running a 3.1? Your problem may never be able to get fixxed. It might be the design of the heads or head bolt pattern. I dont think the 3.1 is really designed to handle tons of cylinder pressure.
ambainb
Apr 25, 2016 09:21 PM
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
