TBI nitrous questions
Old Aug 2, 2006 | 01:31 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
im looking into getting nitrous on my mainly stock 305 tbi with 52k miles on it. i have a 2.5" catback system on it and am soon getting an open element too. i was wondering how the NOS #05153 kit is compared to other kits such as nitrous works. also what is the largest shot i can run with the stock fuel pump which i wont change till it goes cause i know its a PITA. im running ac delco rapid fire plugs that are brand new at stock gap if thats fine? and last question is i want to know what long a 16oz bottle would last compared to a 10 or 5ib bottle i know not as much but it would be a lot easier for me to hide and what not.
Old Aug 3, 2006 | 06:00 PM
Engine: LO3
anybody know what kind of a shot i can run? also which plugs and gap? retard timing?
Old Aug 11, 2006 | 03:45 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
Transmission: 700R4 2500 stall
with a 16 ounce bottle barely a complete run i run a 150 and i maybe get a good 7 passes out of it u et the bottle get to low and it starts slowin down not enough pressure i ran 150 on my stock pump any more look to upgrade. and go with the 10lbs bottle cause if not youl be waisting ur time i usualy have 2 10lbs bottles 1 goes right in were the spare tire goes and u can have 1 for a spare at home when u run out but if ure just getting a 16 oz pointless maybe awright for a 1/8 mile pass
Old Aug 11, 2006 | 05:19 PM
Engine: LO3
yea i ended up buying a 10 Ib bottle anyways. now i just got to figure out timing spark plugs and jets still
Old Aug 11, 2006 | 05:32 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
if ure trying to be safe run 8 degrees of timing as for jets what do u have nos nx if its nx 100 shot 52n31f 150 62n35f if u have nos call themor let me no what kit u have theres a nitrous calculator online u just put ure fuel pressure and the nos jet size and it will give u the fuel jetting Nitrous Oxide Jet size and HP Calculator nos n2o if u have any ? send me a message ill help u figure it out
Old Aug 11, 2006 | 05:33 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
heres the link >>>>>>>Nitrous Oxide Jet size and HP Calculator nos n2o
Old Aug 11, 2006 | 05:36 PM
valencia1z's Avatar
Car: 1986 IROC-Z
Engine: 350 5.7 TPI
heres the link >>>>>>>Nitrous Oxide Jet size and HP Calculator nos n2o just start small work ure way up make sure u have everything working start with a 50 or 75 and work ure way up to the 150 as u feel contrable the motor will stay together double check triple check once u have it all dialed in youl have a blast
Old Aug 11, 2006 | 11:27 PM
Engine: LO3
i got NOS 05153 kit. and i got a 10 Ib bottle to hook it up to too. is that site good for the NOS jets?
Old Aug 12, 2006 | 10:55 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Here's a post from another board I'm on. This guy actually dyno tested it runs at different levels. Just goes to show how torquey the TBI engines are.
Well I got the RS to the dyno today. First NA pull was
176hp
232ft lbs
50 shot
200 hp
306tq
75 shot
230hp
325tq
100 shot
302hp
394tq
I will post the graph when they get it up.
305 TBI small cam (stock LT1 size) 6speed moser 12 bolt 4.10's On Nittor DR. on a Dyno Jet!
I was looking for 250hp and 350 tq on the 100 shot biggrin.gif I let the car cool good and got the bottle temp to 1,100 on the 100 shot. I pulls real good now. (I just need to learn to shift it faster now)
Here's the link to the thread:
dynoed the 305 TBI/N20 - CamaroZ28.Com Message Board
Old Aug 12, 2006 | 11:42 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Damn 126 extra horses with a 100 shot! that's pretty sweet.
Old Aug 12, 2006 | 02:28 PM
Drac0nic's Avatar
that's impressive depending on which kit he's running; don't forget NX rates in rwhp. I wouldn't risk the fuel pump if you value your engine. bite the bullet and change it, the LAST thing you wanna have happen is FP drop while spraying. I'd probably end up getting the racetronix kit and installing it with the 340M fuel pump. It's $170 but what's it gonna cost to rebulid a motor?
Old Aug 12, 2006 | 07:54 PM
Engine: LO3
i got 52k miles i dont need new pump it works like a new so i should be good for a while looks like im gonna start with a 100 shot then bump up to 125 shot thanks for the info that was good.
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
