Changed my turbo setup (pic)
Subscribe
Feb 9, 2007 | 08:24 AM
Here is a before and after picture... Almost done with the after....
Old set up used a N/A cam with 1.6 rockers and a stock motor with 8psi of boost.
New Set Up: completely built motor for boost, lower compression, Dart heads, turbo cam, 1.6 rockers, HSR intake, 950 C ECM, K-member, Drag brakes, Spon Torque arm, manaul steering, TH350 tranny w/2800 stall.
Check here for new setup pic:
https://www.thirdgen.org/forums/cool...ric-water.html
Reply 0
Feb 9, 2007 | 09:30 AM
any before and after numbers? that hsr looks great: how much boost will you be running on the new setup?
Reply 0
Feb 9, 2007 | 10:34 AM
15 psi, No I never put it on a dyno with old setup.... Not done tuning new setup, right now I'm tuning the part throttle cruise.
Reply 0
Feb 11, 2007 | 06:47 AM
That looks great!
Sounds like shes gonna run like a bat outta hell. What kind of power are you hoping for?
Reply 0
Feb 11, 2007 | 08:32 PM
I want 500 at the wheels....
Reply 0
Feb 11, 2007 | 08:34 PM
Quote: I want 500 at the wheels....
that should be no problem with what you have done.
Reply 0
Feb 11, 2007 | 09:25 PM
My real goal is to run low 10's in 1/4, I keep teasing my wife that I might run the car on "PINKS". Since this is my project car and not my daily driver, I wouldn't be to to upset if I lost....
Ray
Reply 0
May 11, 2007 | 06:36 PM
Re: Changed my turbo setup (pic)
what size charger you runnin ?
is it intercooled ?
Reply 0
May 11, 2007 | 07:38 PM
T70..... Yes it's intercooled. I just had to upgrade to 65lb injectors because my 42lb's were going static at 14psi and 5500 rpm. I'm gonna try for 16 - 17 psi on pump gas.
Ray
Reply 0
May 11, 2007 | 10:08 PM
I have so many questions for you!!! Where in south Florida are you???!!! Is the turbo actually a garret? Where did you get the injectors? Did you build the kit yourself?
Reply 0
May 12, 2007 | 09:14 AM
I think he has a post on his build from before also.
Here are some pic's i have of his car.
http://www.cecoatings.com/images/oth...ars/rtkjadams/
Reply 0
May 12, 2007 | 09:35 AM
Dude , I need to bug you about your intercooler . Like where did you get it ??? I need one and , am affriad to just plop cash down for one ...not sure if it fits , etc. My turbo is being put in as we speak ...any help would be appreciated .... Sorry for the hyjack ..NICE SETUP !
Reply 0
May 12, 2007 | 02:45 PM
Hey Ray,
I was curious if you felt that using the stock intake was being a restriction on your boost?
Have you had the car dynoed yet ?
I was thinking about going holley stealth just for ease of switching out injectors..
Rob
Reply 0
May 12, 2007 | 07:18 PM
Quote: Dude , I need to bug you about your intercooler . Like where did you get it ??? I need one and , am affriad to just plop cash down for one ...not sure if it fits , etc. My turbo is being put in as we speak ...any help would be appreciated .... Sorry for the hyjack ..NICE SETUP !
i "THINK" he has the same FMIC I do.
http://www.cecoatings.com/images/Car...rboMotor/FMIC/
I got mine on ebay cheap. Did alot of reading on it 1st also. It seems like the 4thgen guys like it for a budget fmic.
http://cgi.ebay.com/ebaymotors/31x11...QQcmdZViewItem
Rob
Rob,
With a boosted least of your worries should be a intake,heads,etc. Depends on your HP goals and how much $$ you want to spend. Id say stick with the stock intake for now. Invest in a GOOD fuel system and tuning stuff 1st.
Some verry good reading for you.
703 whp 723 ft. lbs torque! STOCK TPI
http://www.theturboforums.com/smf/in...?topic=61219.0
Reply 0
May 14, 2007 | 03:54 AM
When i was looking at the pic of you're new setup i seen the low-mount alternator bracket, what brand is that? do you have a part # and a price? thanks
Brandon
Reply 0
May 14, 2007 | 08:44 AM
What are you going to do with the air intake to the turbo? I also have the Commander 950, how much timing are you going to run under boost? What is your compression and are the dart heads iron or aluminum?
Reply 0
May 14, 2007 | 11:34 AM
wow.. clean setup man.. i must like it cause i got wood.. j/k she must haul some serious ***.. post up some numbers when you get them..
Reply 0
May 14, 2007 | 04:41 PM
that thig is sick. whats your compression ratio? where did you find that turbo?
Reply 0
May 27, 2007 | 12:07 AM
Brandon, PM sent about alternator and bracket......
D's89IROC, As far as the intercooler, I removed the AC condenser and measured to see the biggest intercooler I could find..... It fit perfect, but had to do alittle trimming to get the the inlet / outlet pipes to connect. Check ebay there is tons...
Imthebriman, I'm in Pembroke Pines. I got my new 65 lb Bosch injectors from Musclemotors.com, after I got these I found a place that sells 62lb injectors for much cheaper (Oh Well). As far as the Turbo kit, I did eveything myself expect the Turbo header (BDDS or BBDS) the Turbo is a Master Power T70 with a .96 exhaust housing.
Reply 0
May 27, 2007 | 08:49 AM
Lotek, I got the turbo from "MikeTurboinc.com" , the compression if I remember right is around 8.7-1.
Calebzman, the heads are the Dart Iron Eagle Plat. cast iron w/200cc runners.
Ray
Reply 0
Subscribe
