Any good mechanics in central PA
Any good mechanics in central PA. My car is got me going crazy. Not stock not even close has a FAST ecm. I live in State College.
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
wow i would like to check that bad boy out some day whats going on with it i don't know much about turbos but good with about everything else not to far away.
https://www.thirdgen.org/forums/powe...stributor.html
here is the post
Now the car will start but its very hard to keep it running and only runs for about 6 seconds with me pedaling the hell out of it. I did also replace the pu- coil. Today I will get a new map sensor and try that 2 years ago my map went bad and left me stranded by the road. I guess I'am realy getting frustrated I don't even have someone to help me like turn the motor over while I try to check the timing with a timing light. I did try leaning it out under 2000rpm but seemed to make it worse.
obeymybird What town our you in?
Things replaced
ICM
pu coil
verify rpm signal at ecu
bypassed msd coil and mallory ignition with factory coil so coil/ignintion box our not the issue
My tps read 19 with engine of and runs up to 94 when floored.
Maybe my new ford style tps is goofed I bought it new from precsion turbo
Tried running demo start up from FAST file
injectors are all good reading 2.7 72# low impedence
here is the post
Things replaced
ICM
pu coil
Car: 92 camaro RS
Engine: LSA
sure anytime always looking for something to do i have a ton of work to do to my car just waiting on some better weather
yes I got it figured out. I had a coil wire at a connector that was just about cut in half. In the process of cranking and misfiring for 3 weekends i fouled the plugs. I put a new set in and it runs ok, now I just need a good tune with my new single plane setup.
Car: 92 Z28
Engine: Boosted LSX
awesome, I figured it had to be something small and stupid. Its always them little things that get over looked.
as I said I had a wire pinched before and took me weeks to track it down also.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
litemupp
Aug 23, 2015 10:09 PM
