nos and fuel
Old Feb 27, 2007 | 04:56 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
nos and fuel
I was wondering i have a stock tbi fuel pump i converted to carb and kept the fuel pump. i am using a mallory return style afpr. i want to run a powershot nos system on my 350. my questions are.
1. how much psi does nos and running the car at 5.0 psi require. does a tbi fuel pump have enough to handle it?
2. If the fuel pump does have the ability, will a tpi fuel pump work and can the mallory afpr be able to handle all of the excess psi?
3. what books or web sites are there for nos to learn more tips and tricks on how to setup and tune nos. I know how to install, just my first time with nos.
thanks in advance.
Old Mar 3, 2007 | 10:40 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
ttt
Old Mar 3, 2007 | 11:54 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
thanks in advance.
You need 7psi flowing to the carb, and around 6psi flowing through the nitrous. You can have enough pressure, its the volume you need to be worried about. It needs to hold 6psi all the way through the run, not just while the car is idling. If that fuel pump can't keep up with both the nitrous fuel and the carb, it will lean out and you'll burn a piston or valve. I'm not sure on the specs of those type pumps.
Old Mar 3, 2007 | 11:58 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
would a tpi pump be able to handle the volume or do i need to upgrade to a holley blue or something.
Old Mar 4, 2007 | 12:22 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
walbro255lph intank will easily flow enough for them both and that can be had for about 120 bucks with a hotwire kit from TSP
Old Mar 4, 2007 | 12:36 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
just wondering what is a hotwire kit?
Old Mar 4, 2007 | 01:10 AM
Car: 91 z28
prettymuch a relay that gives more juice to the pump so it can flow at its max potential
Old Mar 5, 2007 | 10:52 AM
89_ho_rs's Avatar
Car: 1989 RS Camaro
so would the stock fuel lines and an in tank pump be able to handle it. or should i put in a holley blue pump with bigger lines? and if so will my afpr be able to handle the volume of fuel that it needs to return?
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
