What cam for Lightning 200 heads
Old Mar 23, 2007 | 12:37 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im building a 383 and planning on RHS Lightning 200 heads. It'll be a blow through carb system with a mighty demon. Im stuck on what cam to get. I was going to use the comp cams xr282hr but its on a lsa of 110 and its dual pattern.
Its a mostly street car, so I'd like to keep good low end torque, peak hp not much higher than 6k rpms.
Probably a th400 tranny.
The supercharger is a vortech s-trim. 7-8 lbs of boost.
The only thing I have right now is the supercharger, so any other parts advice would be appreciated.
MoJoe
Sep 24, 2015 09:12 PM
michealleger
Aug 26, 2015 03:29 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
