DOES THIS NOS KIT LOOK GOOD!!!!?????
Old May 8, 2007 | 09:17 PM
02 camaro's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 305 T.P.I V-8
Transmission: M5
Axle/Gears: 372's
A guy want to trade me for both of my E-maxx's for hisnot kit he said it comes with EVERYTHING..and he said t works!...It has the 50Hp shot on it now!...where is a place t get the plate the would go inbetween my T.B.I for the nos hookup!
Old May 8, 2007 | 09:58 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: DOES THIS NOS KIT LOOK GOOD!!!!?????
you want to spray your 4 cylinder camaro? oh man. Also the kit looks complete, but without a nozzle or plate to put under the tbi it won't do you any good.
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Looks good if you can find a plate. I wouldnt trade 2 emaxxes for it though. Maybe trade just for one and you wouldnt have a bad deal. .02
Seth
Old May 8, 2007 | 10:17 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
well actualy neither of them work!..one need and esc the other is a parts one and doesent have a tranny!
Old May 8, 2007 | 10:23 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Yes but i'd want to get a nozzle thingy to only add 15-20Extra Hp...and ya what and where can i get a nozzel!?..and where can i get a spacer!..im looking!
Old May 8, 2007 | 10:31 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Looks to me like there is a nozzle, at the end of the two hoses coming off the solenoids (in teh middle of the back window).
What are "emaxxes"?
Old May 8, 2007 | 10:35 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
an electric traxxas off road remote control car! and i meant a injector to only add like 15-20Hp
What are "emaxxes"?
Old May 9, 2007 | 09:09 AM
Ahh, I know the Traxxes was kinda expensive a few years ago, but if it were me, I'd probably trade both, especialy if they are both broken.
I don't think you understand how a nitrous system works, or is adjusted. You don't change the nozzle, it's a nozzle, not an injector, you change the pills or jets that are usually located at the nozzle, held in by the lines connected to the nozzle. There will be two different sizes in a wet system such as that, and in a matched set will use the larger pill in the fuel side. This is largly due to the presure differnces between nitrous and fuel systems, close to a 1000 PSI difference.
Old May 10, 2007 | 04:55 PM
pairtoe's Avatar
exactly, also why only use a 15-20 shot thats just pointless. throw a 75 shot on. it wont hurt nothing
but couldnt he just run the nozzle bfore the tb and skip the plate all together. ive never seen the engine of a 4 cylinder camaro so im not sure. post a pic of it if you got one.
Old May 10, 2007 | 08:10 PM
IIRC all 4 cyl F-bodies used a TBI set-up, that makes it difficult to put the nozzle upstream from the TBI, but not anywhere near an impossible task, just need to be a bit creative is all.
It's easier if the nozzle is an annular discharge type, because then it could be mounted directly above the TB and spray straight in.
Old May 10, 2007 | 08:18 PM
pairtoe's Avatar
got it, a little fab work and it would be possible. but prob easier for him to just get a plate.
Old May 11, 2007 | 08:51 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
The gut that is going to put it on for me said he is going to cut a hole around The aircleaner and stick the nozzle there!...any one heard of this?
Old May 12, 2007 | 08:03 AM
If he's going to do what it sounds like he is gong to do, don't let him touch the car. Youy don't want the nitrous to be sprayed before the filter. Yoiu need the nitrous sprayed on the engine side of the filter.
Old May 12, 2007 | 05:41 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
Well this is what he wrote me!?
"just a hole in the air cleaner about a 3/8 inch hole and your in luck i found the 20 shot nozzle for it but i have to work the whole weekend just found out so how dose next Saturday sound"
Old May 12, 2007 | 07:20 PM
02 camaro's Avatar
Transmission: M5
Axle/Gears: 372's
is that diiferent than doing whta you where thinking?
Old May 12, 2007 | 08:02 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Guy is smokin crack. The way he is doing it is a "hack job"
Now if you buy the right parts to do it like that its a diff story.
Im sure most people havent seen this kit.
http://www.carcraft.com/techarticles...n_nitrous_kit/
Then again for what thats gonna cost you just pick this up off ebay and your all set....
http://cgi.ebay.com/ebaymotors/Cheat...QQcmdZViewItem
Old May 14, 2007 | 03:15 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
First of all those RC cars are worth way more than that nitrous kit. secondly its not made for you're type of car, so you'll probably end up spending another 100+ for the plate. DO NOT let this guy install this kits onto you're car, it sounds like a complete hack job. I would just get a sneaky pete kit if you want only 25 shot, you can buy that kit for like 200 bucks brand new all all you have to do is put a small black tube into you air cleaner and point it down twards the TB..hell you could even hit the bottle and all i the wiper cowl! I think this is just a bad deal for you. i say no go
1992 Trans Am
May 10, 2023 07:19 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
fasteddi
Sep 2, 2015 10:29 AM
TreDeClaw
Aug 14, 2015 06:58 PM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
