Any options with this setup?
Old Jun 2, 2007 | 09:51 PM
4RCEPWRD's Avatar
Car: 82Z28
heres what ive got
350ho crate engine
vortec heads modded for lift
1.6 rockers
xe274cam
rpm air gap
holley 750dp
not 100% sure on compression, it was 9:1
My question is do I have any options as far as supercharger or nitrous that would work well with this combo? Im really leaning towards going the way of a supercharger but am pretty ignorant in this area, if what i have wont work what would i have to do for it to be supercharger friendly? and as far as a nitrous shot could i just hit it with one as is? and if so how big a shot?
Old Jun 2, 2007 | 11:12 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Any options with this setup?
You will definately want to find out the EXACT compression ratio, that will be the determening factor on how much boost you can run.
Other than that, you will probably want to pick up a blower/turbo specific cam.
Old Jun 4, 2007 | 08:35 AM
4RCEPWRD's Avatar
Car: 82Z28
any suggestions?
Old Jun 4, 2007 | 11:18 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
comp cams has a specific cam linup for motors running boost or nitrous.
Even better yet, phone up comp cams, give them your setup and see what they would recommend. They might even make up a custm grind for your app.
Old Jun 4, 2007 | 02:19 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
also, if you are planning on a blow through carb supercharger setup (ie. procharger) then you may need a modified blow through carb.. not completely sure if a regular 750DP will work
Old Jun 4, 2007 | 08:22 PM
4RCEPWRD's Avatar
Car: 82Z28
what about a roots blower, i.e. weiand 142, besides a cam would i also have to swap intakes? and would 9:1 be suitable for one of these?
Old Jun 4, 2007 | 08:42 PM
5678TA's Avatar
Car: 1984 Trans Am
i believe all or most roots blowers come with a intake manifold.. and 9:1 would be good with a 142
Old Jun 4, 2007 | 09:51 PM
4RCEPWRD's Avatar
Car: 82Z28
ive never had the combo im running now dyno'd or to the track but i was told it was good for 400hp, im just wondering if the numbers would be worth it after a cam swap and a 142, i had read that these are pretty much done by 500hp so would that be an attainable number or not in this situation (with 9:1)?
Old Jun 5, 2007 | 09:43 AM
4RCEPWRD's Avatar
Car: 82Z28
well...even if 500hp is attainable, after searching and reading some articles about these little blowers i have reconsidered due to cost to hp gain, it just wouldnt be worth it in my opinion, perhaps next time. I figure i could just spray it and be done with it, ive read good things about the NX Hitman so im just gonna go this route, one more question though. Would the cam i have now be ideal for using spray or should i, like was said earlier switch to a nitrous cam? thanks for the help
Bubbajones_ya
Jul 6, 2024 08:32 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
customblackbird
Oct 1, 2015 04:30 PM
Trevor Tarry
Sep 15, 2015 02:04 AM
64Chief
Sep 12, 2015 08:05 AM
