my car is a terd...
Old Aug 14, 2007 | 10:30 PM
draglover's Avatar
Car: 1983 camaro Z28
Engine: 383 stroker
Axle/Gears: 4:10 full disk posi
my car is a terd...
i want to add more power but dont really know what to do to it its a stock 305 automatic trans the year of the car is 1983 what exactly should i do to it? i want it to have noticable power and sound nice too.
Old Aug 14, 2007 | 10:36 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: my car is a terd...
Exhaust and nitrous.
Old Aug 14, 2007 | 10:50 PM
draglover's Avatar
Engine: 383 stroker
im trying to stay away from nitrous only because then you basicaly have to rebuild the engine just so it can handle it and in the long run its not worth it on the engine i have. i was thinking exhuast and a cam but i dont know what kind of cam to get.
i was also thinking of boring it to .040 or .060 or maby storke it.
Old Aug 15, 2007 | 01:31 AM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I would not spend the time and money to have it bored and to stroke it. If you want to do a 305 build up First off get headers, exhaust and open up the intake side, bigger intake, performer, RPM, Airgap, and open filter. a bigger carb will help too just don't got to big. 600 or 650 would be good. But a good set of headers and exhaust will get you what you want.
if you want cams do a bit bigger then stock, like this one - CCA-12-211-2 or if its a roller CCA-12-412-8
Do a bigger stall and taller gears, 3.73's 4.10's will really wake it up.
Hope that helps
Old Aug 15, 2007 | 02:00 AM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
If you dont want nitrous,turbo, supercharger etc.. you're in the wrong forum..
You DONT have to rebuild an engine to use nitrous. Many people, including myself, have sprayed nitrous on stock motors for a long time. Also if its not worth it with the engine you have, why would you bore and stroke it? Thats rebuilding it too and you do just as much work. My advice is to just get some headers and a decent exhaust on there, and an intake like an RPM airgap or performer RPM. And do some searching around on the board, you'll find this same question is asked and answered a MILLION times.
Last edited by WheelsUp84z; Aug 15, 2007 at 02:03 AM. Reason: Automerged Doublepost
Old Aug 15, 2007 | 09:31 AM
draglover's Avatar
Engine: 383 stroker
i never said i didnt want a turbo or a supercharger but i personaly dont like nitrous
Old Aug 15, 2007 | 09:53 AM
vingta1989's Avatar
Car: 1989 GTA CONVERTIBLE
Engine: 355 tpi
Transmission: ART CARR 700 R4
Axle/Gears: 3.70
buy a crate motor or build a 350 etc....and ditch the 305..dont waste your time and money on a 305
Old Aug 15, 2007 | 10:07 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Stress that you are scared about from the N20 will be just as high with a turbo or S/C. So if you are affraid of N20 stress, then you inherintly are affraid of all power adder stress. Just get and a set of pipes, a cam and N20, you will be faster than you wanted to be and sounds mean.
Old Aug 15, 2007 | 11:12 AM
draglover's Avatar
Engine: 383 stroker
ok i will consider it without a doubt but i never understood, how exactly nitrous works? and dont you have to refill it and stuff? how fast does it run out? and about how much dose it cost to refill it?
Old Aug 15, 2007 | 12:23 PM
Engine: LS3
WOW. those are all questions that can be answered by using the search button. But I will leave you with the nutshell explanation...
N20 works just like a tubo, it adds more air so that you can add more fuel, so that you can make more power. thats it, simple. The nitrogen doesn't get used at all, it just carries the oxygen into the chambers safely. O2 is way too dangerous to carry around pure. Then the explotion happens and the oxygen is used and the nitrogen leaves with the exhaust.
it is literally liquid supercharging.
Yes it need to be refilled.
It runs out based on how much you use it. how big a shot you run and so on. A small shot used every now and then, a 10lb bottle filled will last a long while.
It cost about $5.50 a Lbs. So a 10Lbs. bottle, cost around $60 to fill. (ballpark)
These really are questions you shouldn't be posting about, this info is out there. GO FIND IT!!!!!!!!!!!!!!!!!!!!
Old Aug 15, 2007 | 02:16 PM
draglover's Avatar
Engine: 383 stroker
alright no more questions then.
Old Aug 15, 2007 | 02:24 PM
Engine: LS3
Questions are fine, in fact great, I love answering and helping. But be more precise about what you want to know. Broad things like you asked before just leave you with little help. Buy a performance camaro book. I have 3, read them all 2 times at least. Now I never need to ask simple questions, only specifics about my car. Things move along WAY faster that way.
Old Aug 15, 2007 | 08:33 PM
Maxboost's Avatar
I have a new Borgwarner T04B turbo H trim comp / P trim .84 ar [schwitzer/MP] that I got for a 305 but decide to do a 3.4 v6 instead;will take $350 + shipping.
Old Aug 15, 2007 | 09:06 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
Draglover, do you need to keep smog laws in mind with your car or not? If you don`t need to smog, building power is easier.
Old Aug 16, 2007 | 12:00 PM
draglover's Avatar
Engine: 383 stroker
does it bolt right on? is everything there too?
Old Aug 16, 2007 | 01:28 PM
Engine: LS3
Pretty sure he is selling the turbo for that price and thats it. A turbo kit for $350, that would be friggin' GREAT! Everyone would have one!
Old Aug 18, 2007 | 10:54 AM
Maxboost's Avatar
Please,just the turbo cost $600 +,it's just a new turbo for a good price.
Old Aug 18, 2007 | 03:47 PM
draglover's Avatar
Engine: 383 stroker
but im pretty new to this kind of stuff and to cars in general its a very good price but if it dosent have everything with it i wouldnt know what else i need
Old Aug 19, 2007 | 07:36 PM
Maxboost's Avatar
There are several sites on the net that have good intro articles on turbos and you can learn from doing searches here,it's not something someone can explain in a few minutes. If you'd really like to "turbo" your engine,you will need to have a good working knowledge to make the right choices.
Old Aug 19, 2007 | 08:07 PM
Ford2transam's Avatar
Car: 1983 Trans Am ALL STOCK which is go
Engine: 305low
Axle/Gears: stock
In short I think the best place for you is Ask.com just litteraly ask the question like "How does a turbo work" or Nos or supercharger ect and alot of very easy to read webpage will follow. just my advice on where to start more you understand the easier it is to choose and install
Old Aug 19, 2007 | 08:24 PM
Also try downloading the instruction manual for the TPI nitrous kit from Holley's NOS web site. That taught me quite a bit about nitrous right there.
Old Aug 19, 2007 | 09:22 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
If your wanting forced induction, I'd just do a Weiand 142 roots blower. A lot easier setup than a turbo, and isn't really that expensive these days...
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
