twin turbo oil line routing
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
where is everyone tapping into the block to get their oil feed? I was told one of the 2 bolts that are above the oil filter? pics would be nice
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: twin turbo oil line routing
run a t-fitting off the oil pressure sensor
Car: 91 z28
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
It is pressure there too, it is after the filter.
You have four locations where you can get oil.
Using an oil filter adapter.
Using the oil temp sensor above the oil filter.
Using the oil pressure sensor behind the intake manifold.
Using the plug above the water pump.
Car: 1984 Z28
thanks this is what i wanted to figure out. Would using the plug above the water pump have enough flow since I remember the plug being rather small in size 1/8" maybe? Rather than the bolt that is right above the oil filter being larger in diameter.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Plug above the water pump? Someone have a picture of this? I didn't think there was an oil line with plug there...? I can only picture the 3 pipe plugs at the end of the main oil galley lines... That's below the water pump isn't it?
If that's the area in question, it's a 1/4 or 3/8" pipe plug, so at least 3/16" of flow area at the very least.
Is this a journal bearing or ball bearing turbo style? From what i've heard you don't need a whole lot of flow to the turbo.
Here...
Not all blocks have this. Sometime in the 80s they quit putting it in all of them.
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
I went with the plug above the water pump in my 1975 (truck) block in my camaro.
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I have one oil line coming from above the oil filter at the 1/4" NPT hole. The other line comes from the TEE at the rear of the block under the distributor. Both lines have a .063" flow restrictor from Mcmaster-carr.com at the turbo inlet.
Car: 1984 Z28
can both turbos be fed off the line coming above the oil filter? I'm assuming this would not need a restrictor either on 2 stock GN turbos.
Car: 1984 z28
Engine: BBC
Transmission: TH400
you can buy a sandwich plate to go between the block and the oil filter, that will give you 2 big oil lines for the turbos
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
I installed a T right above the oil filter one side is to feed the turbos the other is for the switch. I see 60 lbs of oil pressure at idle. I do have a high volume oil pump though.
bjpotter
Jan 22, 2019 12:27 PM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
