HELP! extremely bad MPG w/ supercharger
Old Dec 14, 2007 | 12:14 AM
RiggsLW81's Avatar
Car: 1987 IROC-Z Camaro
Engine: 350 (5.7L)
Transmission: 700R4 (Auto)
please post what kind of MPG you get with your supercharger (and what kind of set up u have). also how many miles per tank do u get?
i just had a vortech supercharger installed with a lingenfelter supperram set up (on a 350) and on the first two tanks of gas (since the install) im averaging only 8.5 mpg !!! i get around 100-110 miles per tank...the motor is a 350, rebuilt, new plugs and wires, running mobil 1 synthetic oil...im not even 'heavy footed' this is just basic driving...need help !!!!!! anyone who can lend advice speak up!! ive heard that new motors need break in time and this can cuase bad mpg but 8.5 mpg is rediculous !!! i only run 93 octane too..
Old Dec 14, 2007 | 01:35 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: HELP! extremely bad MPG w/ supercharger
so go get a better tune done....? when you're out of boost it shouldn't be that bad.
Old Dec 14, 2007 | 02:18 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
only roots blowers are supposed to give bad mpg all the time..
btw, i get 8.5 mpg N/A...
Old Dec 14, 2007 | 11:22 AM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I don't know where you heard that....... if you drive a roots with a light foot it will get better gas milage than without !
Old Dec 14, 2007 | 12:16 PM
flrtin1's Avatar
Engine: S/B
I agree with xpndbl3, if you truely are driving with a light foot ( hard to do with new power ) and getting poor milage I would look at your tune.
Old Dec 14, 2007 | 01:02 PM
xpndbl3's Avatar
Car: 1984 Z28
thanks shawn, i agree with you too And you're mr. blower from all those pics, so I'd believe you 100%
Old Dec 14, 2007 | 02:19 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Huh...I was getting 22.6 avg MPG (25 hiway MPG) with my blown 350 and 4.10 gears. It was a Weiand 142 with an Accel 4 barrel TBI (with 4, 86# injectors) and Rbobs EBL.
Old Dec 14, 2007 | 04:59 PM
Guest
Guest
Posts: n/a
Its something other than the supercharger. My mileage hasnt changed unless I'm racing... in which case the mileage is awful. But there's a lot more power
Old Dec 14, 2007 | 05:54 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
i get about 5....N/A...cant wait till the blower is on...wohhhooo
Old Dec 14, 2007 | 06:30 PM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
I know what you need to do!!!!!!
Take the SUPERCHARGER OFF GIVE IT TO ME,YEA!!!!!
THAT will make the gas mileage better!!!!!!!
lol
Old Dec 17, 2007 | 12:40 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
i know its running rich...as my mechanic told me it is. would leaning it out a bit help? also, can some explain to me exactly what is involved with tuning a supercharged vehicle? what is tested/checked/changed? and how exactly is it done?>...i would like to know as im new to having a supercharged car.
Old Dec 17, 2007 | 01:03 AM
5678TA's Avatar
Car: 1984 Trans Am
i stand corrected..
Old Dec 17, 2007 | 01:09 AM
xpndbl3's Avatar
Car: 1984 Z28
boosted cars aren't something for a novice to tune. Go take it to a dyno shop that specializes in them and pay to have it wideband tuned on a dyno, only way you'll get it right. N/A motors are more DIY'er but one lean spot on boost and you're done.
Old Dec 18, 2007 | 05:13 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I don't know if this will help you but.. It might be in the F.M.U. Thats the fuel managment unit. Got to see if its working right under boost applications. I think your fuel pressure should be around 35-40psi driving around without boost. Under boost it will spike up a little more depending on fuel demand (where dyno tuning comes in.) My car would spike fuel pressure to around 80psi under hard boost (12psi). But still got around 190-200 miles a tank with a 383. Good luck
Old Dec 20, 2007 | 09:30 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Axle/Gears: 10 bolt 3.08
True, people don't seem to realize that Roots blowers utilize a valve to vent boost when not needed (idling, low RPMs), lower parasitic hp loss and increases mileage. In town, roots blowers can actually INCREASE mileage. Contrary to popular belief, they have evolved since the style of design was patented in 1860 (by Philander and Francis Roots of course).
Back on topic, a good dyno tune is probably just what you need
Old Dec 20, 2007 | 10:09 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
Actually only the newer Eaton's have the bypass valves. The Wieand's and B&Ms don't bypass them. They supposedly increase MPG because they're more efficient at stuffing air into the engine.
All this talk is making me jealous that my 144 is just supercharging my work bench.
So far with the mods in my sig I'm only able to get 15mpgs, but I didn't build it to baby it.
Old Dec 21, 2007 | 07:53 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
Weiand says they use the bypass valve on their blowers, you sure they don't?
Old Dec 21, 2007 | 10:10 PM
trumps2000's Avatar
Car: 1985 Z28
100%, took mine apart, but mine's the smaller 142/144 variety, not sure about the big boys, but dunno why those would. They told you that on the phone?
Old Dec 21, 2007 | 10:20 PM
rmmstnr's Avatar
Car: 89 TA
Engine: 305 TBI
No, it was in their supercharger catalog. The catalog has a good sized section where they go over supercharger details and info. I suppose that doesn't at all make it true, but I didn't think they'd fib on that
Old Dec 21, 2007 | 11:04 PM
trumps2000's Avatar
Car: 1985 Z28
Weird, maybe its an addon?
Old Dec 22, 2007 | 04:19 PM
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
You need to put a Wide Band O2 on the car. With out that your driving blind.
Tuning off the narrow band just won't cut it anymore. I use the AEM Widband on my stock ECM Cars.
Tuner pro will be able to edit your factory ECM. If your using a FMU... Ditch it. They are not going to give you the right AFR for all driving that a street car does.
If your not willing to learn how Tuner pro works and alot of stuff about hacking the factory ECM then go Aftermarket. FAST... or DFI. It's much more user friendly.
There's no reason why your getting the MPG you do except for a very Poor Tune.
~Scott.
Old Dec 26, 2007 | 01:22 AM
RiggsLW81's Avatar
Engine: 350 (5.7L)
i do have the FMU installed from vortech...(ur50slow) can u expalin why the fmu cant handle the needs of everyday driving? (this is not a strip car but as much of a daily driver as possible...but as powerful it can be as a DD with decent gas milage). i spoke with my engine builder, he told me he did a very basic tune on the car just to help break it in as the engine was rebuilt in addtion to the vortech supercharger and lingenfelter top end. i told him about my terrible gas milage and he said we could address that once its good and broken in (were agreed around march--giving it plenty of break it and daily use over that time period), he did mention getting it on the dyno at that time and doing a proper tune, as of now it hasnt been on the dyno yet.
can ui explain to the difference between 'wide band' and 'narrow band' ? im not familiar with the difference...thanxx
Old Dec 26, 2007 | 02:08 PM
UR50SLO's Avatar
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
The FMU is nothing real fancy.
Your normal Fuel Pressure Regulator increases fuel pressure 1-1 with boost.
So every 1 psi of boost you get 1 more Psi of fuel pressure.
Your FMU however is setup depending on a diaphram inside to double/triple or more your fuel pressure depending on boost. So... Your boost go's up 1 psi and your fuel pressure go's up 2 or 3 or more depending on the disk inside.
Now.. with that being said... your ECM knows nothing of of this FMU. It's got the factory programing inside and it will account for some rich/lean in the Intergrator/BLM's (block learn) numbers but it can only adjust so much.
A FMU will never get you a proper fuel curve pushing extra fuel through stock or bigger injectors with the Barro/humidity/temp changes.
And it's not easy on fuel system parts having so much pressure on them when in boost.
If you decide to edit your ECM and install the proper Fuel Injectors for your HP level you'll end up with a longer living fuel system and a custom program that is able to adjust it's self on a daily basis and it's not going to fail as easily. With a system like Tuner Pro you can adjust your spark curves, fuel curves... Cold running/open loop/Idle ect It's limitless realy. But it's going to take some time to learn it.
Now... A Narrow band O2 reads in Mv. (Millivolts) You can tune with one but it's designed to read 14.7-1 Anything above or below it's not as accurate.
(Also called a one wire O2/ or can have 4 if it's heated)
A Wideband allows you to read actual AFR (Air Fuel Ratio) It's accurate over a wider range of your air/fuel that your car experiences.
It's much easier and more accurate to tune with one once you know what AFR to tune for.
Boosted cars like 11.7-11.3AFR at WOT and you can narrow the AFR's down to 14.7-15.3 (Or leaner) when crusing/light load. That takes more experience with tuning and timing to get right.
Being Pig rich isn't always a good thing either. If it's 6mpg and the afr's are 10's all the time you'll end up with fuel in your oil and it's not going to be a good thing.
A Dyno in my openion is a waste of money and time. Your much better off to tune in "real world" conditions with the wind and actual road load on the car. You could tune WOT on a dyno and get some "Numbers" for you to look at but it's not going to dial your car in for every day driving.
There's so much more to tuning than I can explain in a few paragraphs but this is a basic start behind what it takes to program for daily driving with factory ECM's.
The Wide band go's in a 2 1/16th pod on your pillar. 2 wire hook up. (Positive/neg.) and the other lead go's to the 7wire O2.
Be glad to help anytime,
~Scott
Dauntless
Nov 18, 2001 09:24 AM
IceBlue91z28
Sep 16, 2001 06:47 PM
redcamaro83
Jul 25, 2001 01:01 AM
5.0GTA
Theoretical and Street Racing
Jun 24, 2001 07:35 PM
G92Joe
Sep 12, 2000 04:10 PM
