Safe Boost Range.? IE:LO3
Old Feb 25, 2008 | 03:01 PM
blackblazer717's Avatar
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
what kind of PSI can i safely put through a LO3 305. with 9.5:1 pistons in it.
the engine is a fresh GM crate, and its for my friends RS.
he has his mind set on turbo's.
i told him i would ask on here for him
yes, it will be intercooled, and yes its going to be twin turbo's with an electronic boost controller.
any help would be awesome
thanks y'all
LUKE
Old Feb 25, 2008 | 03:05 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Re: Safe Boost Range.? IE:LO3
It's all on the tuning. If you can safely tune it, I would say 10psi.
Old Feb 25, 2008 | 03:33 PM
Car: 92 Rs
yea it will be safely tuned, up at advance dyno tune in New Hamphire.
oh, its a TBI motor too if that helps
Old Feb 25, 2008 | 04:26 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
will the TBI computer even support the HP or tuning for boost?
Old Feb 26, 2008 | 12:07 PM
Car: 92 Rs
yes, brian over at TBIchips.com told me that he can write a program and burn the chip so the knock, will be deleted, 02's will be converted to a wide band and the MAP will be different.
Old Feb 26, 2008 | 12:48 PM
xpndbl3's Avatar
Car: 1984 Z28
the stock injectors won't flow enough fuel though is what i'm getting at.
Old Feb 26, 2008 | 01:57 PM
Car: 92 Rs
oh, well i know im well aware of that bro
turbocity.com has me covered on that, dont worry. i can get any upper injector boss and injector size on there and also carry machined 454 TBI's which stock flow 670CFM theres flow like 715. so im pritty sure thats covered too
thanks
Old Feb 26, 2008 | 02:43 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
You could look into getting the EBL...
Old Feb 26, 2008 | 04:05 PM
Ronny's Avatar
That wont do it. stock ECU cannot see boost. you need an ECU that can deal with boost and a 2 bar MAP sensor. Megasquirt or EBL.
Old Feb 27, 2008 | 12:15 PM
Car: 92 Rs
please enlighten me on the EBL......
Old Feb 27, 2008 | 12:19 PM
Ronny's Avatar
dynamicefi.net or .org. i forget.
Old Feb 28, 2008 | 08:41 PM
soulefood's Avatar
Car: '84 firebird
Engine: Twin Turbo 350
Transmission: TCI competition 350t
Axle/Gears: dana 60 4:56
listen, im running a twin turbo setup on a crate 350 with 8.5-1 compression.. im running a tpi manifold but im also using mass air flow translator pro. go to maftpro.com and just read about their setup. it is a great program and it is way easier to use than megasquirt. your lookin at about 500 smackaroos! with their setup you can also buy their 3 bar map sensor, boost control solenoid... so on and so fourth... trust me its worth looking into.
Old Feb 29, 2008 | 12:04 PM
Car: 92 Rs
sweet soulefood.
ill look into it, im also interested in any other "semi affordable" on-board data logging systems. any other help would be great.!
the car its going into will be trick but on a short budget. so if i can get a complete to semi complete data log setup post up guys, thanks
Old Mar 2, 2008 | 02:01 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Cheaper way would be to use an FMU if the injectors will handle the extra pressure.
I ran 15 lbs on my L03 for about 4 months. Drove it three times a week on the autobahn doing around 110 mph. So it saw a constant 8 psi for about 12 minutes. I put a carb on it though. Tuned it with LM-1. MSD BTM 6al.
Old Mar 3, 2008 | 01:23 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'm not sure how the FMU will work with the TBI but, I know after years of using a 2-bar map setup I won't go back to that again. The resolution is horrible.
-- Joe
Old Mar 3, 2008 | 01:57 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
There are FMUs with different pressure ratios. They come with the vortech systems, but those are only meant for like 6 lbs of boost. Much more than that and I'm sure its not going to be very accurate as its linear.
I've never played with one, I dont know how close it gets your fuel ratio to being correct. If you used an adjustable regulator, I would imagine that you could get it close.
Of course assuming you run under 10 lbs.
$750 L98
Feb 1, 2025 02:25 PM
customblackbird
Oct 1, 2015 04:30 PM
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
Doobie52
Sep 11, 2015 06:19 PM
