STS Turbo on a 3rd gen??
Car: 1989 Iroc-z
Transmission: 5 speed
Axle/Gears: Posi
Has anyone seen (without it being a ls1 or lt1 swap) a STS remote mount turbo on a third gen camaro? Aweful expensive to buy the ls1 kit and rig it on there...whats everbody say? seen it? done it? if so pics please.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: STS Turbo on a 3rd gen??
They make a universal kit.
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
Yep... call their tech line and let them know your setup and they'll put together a universal kit that fits your needs~
Car: 1989 Iroc-z
Axle/Gears: Posi
no ****? that theres pretty good customer service.. you wouldnt happen to know how much a "custom" app would differ in price from the regular would you?
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I got a quote about a year ago for my 88 camaro and believe it was 3000.
The man you want to talk to is Freddy Polo
The phone number is 1-866-938-8726 Ext=809
Hopefully this helps
Car: 1984 Camaro Z28
Axle/Gears: 4th gen auburn 3.42 disc
just build your own rear mount system if you have a welder, its rather easy. A lot easier then installing a turbo in the engine bay.
Car: 1989 Iroc-z
Axle/Gears: Posi
Anybody think it'd be worth the $ turboing my 305 tpi with 130,000 on it? or should i look elsewhere?
Car: 1988 Camaro
Engine: 383 Stroker
I think money would be spent elsewhere. Possibly rebuilding the engine, transmission and possibly beefing up the rear end. With this setup, your going to spend a load just on the car just so it can handle the power your going to want to achieve.
My
My
of course, build your turbo set up on the 305, work out all the kinks and quirks in the turbo set up, get it so its how you like it. Then go out and build a forged 350 swap your turbo set up you built for the 305, and since all parts are inner changeable you'll now have a boosted fully forged 350(+). Up the boost and enjoy.
Car: 2004 GTO
Good luck!
bjpotter
Jan 22, 2019 12:27 PM
