Need help on lb9 NOS please...
Old May 8, 2008 | 11:11 PM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
I am a little new to the world of NOS. So, I was wondering if anyone could point me in the right direction here... I need some recommendations for a complete nos kit please. Stock internal 305 so I need the safe recommended shot too.
Old May 9, 2008 | 02:10 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
Re: Need help on lb9 NOS please...
get the nos tpi system, its adjustable from 75-150 shot i beileve.. most say you can safely run up to a 150 shot on a stock motor. under wot. do you have any exhaust mods? you should also run a hotter ignition system to burn everthing up better. maybe do a search and check for what spark plug gap is the best for ya..
Old May 9, 2008 | 04:34 PM
Nater36's Avatar
I just have a 3" pipe from the cats back to a 3" y into 3" tips... I plan to put on some high flow cats when i install the NOS kit... thank you for your help
Old May 9, 2008 | 05:38 PM
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Here's the one I'm planning to get. Looks like the best value in a start up kit.
http://cgi.ebay.com/ebaymotors/ws/eB...m=170217863388
Old May 11, 2008 | 10:20 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I just finished installing a NOS# 5151 kit on mine. I went toward the safety route and installed a fuel pressure safety switch, 75hp jets to start off and all the accessories: purge kit, bottle heater, bottle blanket, and around $30 worth of A/N plumbing for the schrader valve. I knew I was going to add some HP in the future so I started to replace the fuel pump and added 24# SVO injectors last year. Whole system around $800
Old May 11, 2008 | 10:06 PM
Nater36's Avatar
wut is a sniper kit like? would it really give me the 75 hp shot it claims? Also, did that kit have EVERYTHING i would need or would i have to buy something to change the timing when i used it
Old May 12, 2008 | 02:02 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
just get the nos tpi kit, it has the tb plate, dont forget a wot switch.
Old May 12, 2008 | 02:21 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
hey 91b2l got any pic sof ur set up, i just bought the exact kit, plan on installing in the near few weeks just wondering on where to install, also on the purge valve got a part# i dotn believe i have that thanks
Old May 12, 2008 | 08:55 PM
Nater36's Avatar
where do i find the nos tpi kit? ebay?
Old May 12, 2008 | 10:37 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
http://store.summitracing.com/partde...5&autoview=sku
http://store.summitracing.com/partde...view=32&N=700+
http://www.holley.com/data/Products/...A5060-SNOS.pdf
http://static.summitracing.com/globa...05151nos_w.jpg
Good Luck...
Old May 17, 2008 | 11:08 PM
Nater36's Avatar
thanks guys
Old May 18, 2008 | 08:36 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I went with an Edelbrock purge kit. P/N 72176 around $105. It comes with a long flexable plastic tubeing. I'll post some pics of purge and bottle mounting.
Old May 18, 2008 | 07:36 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
here is the bottle mounted and system with purge
Attached Thumbnails Need help on lb9 NOS please...-dcp_1573.jpg   Need help on lb9 NOS please...-dcp_1575.jpg
Old May 19, 2008 | 12:36 AM
Nater36's Avatar
nice, wut all came in that kit? 105 is cheap, was that with everything u needed?
Old May 20, 2008 | 10:48 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
everything I needed, I taped into a hot wire under the console for the power. The one thing I did add to the TPI NOS was an extension to the TPS on the throttle body.
Old Jun 2, 2008 | 09:59 PM
86 IROC's Avatar
Being you have a manual transmission, a window switch wouldn't be a bad idea. It's a cheap investement compared to a missed shift and a broken motor.
junior419
Apr 7, 2025 11:35 AM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
IROCZ1989
Sep 4, 2015 11:54 AM
