vortec and MPT70 combo???
Old Jun 23, 2008 | 04:44 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
8.5:1 with 16 pounds of boost, super victor, CSU carb, vortec heads with 2.02/1.60 valves and mild port work, Lunati hyd roller with 232/242 .510/.525 110LSA.
Will be using ebay stainless headers and then fabbing up an intercooler system and using methanol injection.
What kind of power would this combo make as listed, through a T56?
Old Jun 23, 2008 | 05:31 PM
whiteghost7's Avatar
Car: 92rs
Re: vortec and MPT70 combo???
How big a motor? Assuming 355 ci I'd say around 620rwhp or so, mostly limited by the turbo running out of breath. I'm building a similar but milder combo right now and should have it to the dyno by the middle of next month.
Old Jun 23, 2008 | 06:32 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
DAMN! THAT MAKES ME FEEL GREAT!!!!! I HAVE BEEN TELLING EVERYONE that EXACT figure!!!!!!!!!!!Im doing it. That will be PERFECT! Use about 10lbs on the street for about 550-580rwhp! AWESOME! Im DOING IT! Yes, I would be pretty much yelling right now. Im stoked.
What is your setup???????
Would an 88mm be too much????
Last edited by z28freak84; Jun 23, 2008 at 06:36 PM. Reason: Automerged Doublepost
Old Jun 23, 2008 | 07:21 PM
vwdave's Avatar
Just slightly. I mean, it'll work, but it will lag more and such.
I would go with a S400 from Dave@majestic turbos. Get one with a T04 .96 exhaust housing and let it go. IIRC, Its a 72mm (inducer) turbo that will go to about 850-1000hp.
I think you can buy them for under $700.
Old Jun 23, 2008 | 08:33 PM
Car: 92rs
Is this a street car?
The BW is a great turbo too but will definitely be a bit lazier with the T56 and small motor.
My combo is a 9.1:1 350sbc with a mild cam (220-230) and stock vortec heads, a demon carb and MP t70 on a bbs header.
Old Jun 24, 2008 | 12:21 AM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
what kind of power do you think YOURS makes?
do they make the S400 with a T4 flange??
Old Jun 24, 2008 | 08:56 AM
Car: 92rs
I don't think the S400 comes with a T4, it would choke the flow too much (call Dave at Majestic though as he's a BW expert and a good vendor.)
I'm hoping for around 450rwhp @ 8lbs and eventually 500rwhp at 10-11lbs. Mine is purely a street car that will stay under 5700rpms while retaining good manners and reasonable milage.
Old Jun 24, 2008 | 12:06 PM
vwdave's Avatar
I dont think it will choke it tooooo bad. I mean, I would think it would flow 700-750hp on the exhaust side. If he wanted to go big then yes I would go with a T6 with a 1.0x a/r.
Old Jun 24, 2008 | 01:02 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
Well, I would like to end up as close to 1000rwhp as possible in the future with a different head and cam combo and maybe a 383ci.
Old Jun 24, 2008 | 04:14 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The 1.10 A/R backpressure will be too high for that goal. I would go with the 1.32 A/R housing. Once you narrow in on your HP goal then you can use the Garrett turbine flow maps and compare the BW exhaust wheels and housing A/R to see how much HP the turbine will flow. The 1.10 A/R turbine and 1.32 A/R have different exhaust wheels. The 1.10 A/R has a wheel comparable to a Garrett GT4294 and the 1.32 A/R wheel is closer to the GT45 series.
Old Jun 24, 2008 | 07:38 PM
vwdave's Avatar
1000hp? If you want that to be reliable be prepared to spend around $10,000 in a motor. These are rough guesses. I might be off a few pennies here and there.
Dart block 2300
Oliver rods 1400
Lunati Dragonslayer crank, probably 1000
Dished pistons, probably 1000
Headstuds 150
Headgaskets 200-300
AFR 195 eliminators, like 2200 with competition port and full options
Thats roughly $8000-8500 in just big stuff. Thats not all the gaskets, cam, lifters, intake, carb or EFI, machine work, assembly (in this case, if youre not a experienced builder, dont bother) oil system, cooling system, SFI damper, transmission to hold that power. Good god I can keep going.
Old Jun 25, 2008 | 06:02 PM
Reputation7's Avatar
the new t4 secret is an S380. its a T4 turbo too.... .87 on the exhuast side iirc....
its the one you need, i know for a fact you can make north of 1000whp with it.
edit: spoots quicker than a gt42-76
Old Jun 26, 2008 | 12:19 AM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
How much is an S380 turbo? Its sounds like what I need....What Kind of power would it make on this setup?
Old Jun 26, 2008 | 12:37 PM
id say you could make upto 1000+ with the right engine, however.. i wouldnt suggest it on a stock block / internals.
but on low boost ie: 10psi, id say north of 600hp with the 355.
Old Jun 26, 2008 | 03:21 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
Im wondering how much RWHP I could achieve with a forged 355ci. with some UNported Vortec heads, super victor, CSU carb, lunati hyd. roller 232/242 .510"/.525" 110lsa 9.0:1 and 14-16psi. intercooled?????
will also have beehive springs with titanium retainers and 1.5 roller rockers.
Old Jun 26, 2008 | 04:09 PM
WheelsUp84z's Avatar
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Yes they do they are the s-400 sx they come in t-4 flange however they are roughtly 3x the amount of a t-6 flanged s-400
My first motor was a 9.1:1 355 with mp t-70. afr 195 heads, vic jr, and a 228/228 cam. On 14 psi with 94oct. and 17* timing it put down 580rwhp. The second motor was the same rotating assembly but i had a "half fill" done on it and splayed main caps. I also upgraded to a 76mm. on 18psi and 110 oct i was right at 700whp. a good block with splayed caps and a short fill will hold up just fine to 1000hp if the tune is good and the RPMs stay below 6500. I would suggest you change that cam, you'll be much better of with one on a 114 LSA. I dont see why a VERY conservative and streetable setup like yours wouldnt make 500whp.
Old Jun 26, 2008 | 06:21 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
thats a badass setup. I want to make 550-600rwhp, about 580.
How much is a S380 t4????
Old Jun 26, 2008 | 06:34 PM
contact dave at majestic turbo... he can beat any price on the net for one of them.
Old Jun 27, 2008 | 01:59 PM
Car: 91 z28
+1 thats who supplies my turbos! Dave's the man!
Old Jun 29, 2008 | 06:13 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
How big, physically, is a S380? Is it smaller than a t76? will it work with the BBS header design and clear the hood?
Old Jun 30, 2008 | 04:37 PM
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
New Question...How much horsepower will a 8.5:1 383ci with 270cfm Ported Vortec heads and a 242/248 .5xx/.5xx" support? 700rwhp, 900rwhp? how much? I'll take all I can get.
Old Jun 30, 2008 | 08:03 PM
vwdave's Avatar
How much can it support in what way? Can it make 700+HP? Or can it survive making 700+HP?
There is alot of variables that go into it.
What block are you using? Filled? What mains setup do you have? 2? Straight 4? Splayed 4?
What brand crank/rods/pistons do you have? Whats your ring gap?
What type of headgaskets and what type of retention? Are you using ARP bolts or studs?
What type of valves and springs are you using?
Answer those and I'll get back to you.
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
69GTOby
Apr 18, 2016 02:34 PM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
