Nitrous on a L98
Old Aug 4, 2008 | 06:59 PM
Samdweezel05's Avatar
Nitrous on a L98
How much can I run on a factory L98 bottom end before it turns inside out? How much can you run with nothing more than a cat back exhaust? Thank's
Phil
Old Aug 4, 2008 | 07:49 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Nitrous on a L98
Seems like people run a 100-150 shot pretty well on stock v8s.
Old Aug 4, 2008 | 07:55 PM
That is what I thought. There are things in the works for the wifes GTA and I want to see a little blue bottle in the trunk.
Phil
Old Aug 5, 2008 | 08:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
I use to run a 150 shot on my last Z with a stock bottom and had no issues after about 20 bottles went through it
Old Aug 6, 2008 | 12:34 AM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
my 305 held up to 10+ bottles of 125-150+ shots for a couple years and never quit not even before i swapped to a 350. opened the old 305 up and it was clean as a whistle no issues i could find what so ever.
Old Aug 6, 2008 | 12:47 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
If you do it right 150 shot won't hurt anything. But be carefull that stuff is like crack. Once you spray it you can't stop.
Old Apr 8, 2011 | 09:25 PM
jeremymsl's Avatar
Car: 89 Iroc z camaro
Axle/Gears: stock
i know this is old but hopefully someone replys, i wanna get nos for my 89 iroc tpi 350 but i dont wanna blow it up, i have 13x,xxx miles on the engin but its my only car so i cant blow it up but im sick of only getting like 200-225 horses to the wheels, 2010 accords can beat me D:, so i was thinking 50 75, MABY MABY 100 shot?
Old Apr 13, 2011 | 01:23 PM
bduffey723's Avatar
Car: not a camaro anymore
go 150. just tune it right and let go of the button when u have a feeling something is wrong. never take nitrous away, add more fuel when tuning. i went carbed so it was very easy. im sure FI itll be 10x worse to tune.
Old Apr 13, 2011 | 01:40 PM
Pab's's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI with zz4 heads
Axle/Gears: 9 bolt BW
noob question what would you change (engine wise) in order to make sure you dont blow up the motor, pistons?
Old Apr 14, 2011 | 01:12 AM
89Camaro89MI's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
That's actually a pretty hard one to field. There's a lot that can go wrong when you crank up the horse power. Stock pistons should be fine, along with stock crank shaft.
Valve springs would be a good place to start. Ideally, some nicer springs will prevent your valves from staying open past the timing of the cam and getting slammed into place by the piston returning to TDC. My dad blew a valve up through his hood like that once.
Probably the best thing you could do would be a high flow/ electric water pump and some other cooling system goodies.
Old Apr 14, 2011 | 01:41 AM
Pab's's Avatar
Car: 1988 IROC-Z
good to know ill look into that before I spray it....just want to make sure it stays put
Old Apr 14, 2011 | 11:51 AM
bduffey723's Avatar
i would suggest forged parts if u have the money. it allows for more tunning "error"
Old Apr 14, 2011 | 12:29 PM
Pab's's Avatar
Car: 1988 IROC-Z
what forged parts?
Old Apr 14, 2011 | 12:41 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Forged parts meaning rotating assembly: Pistons, rods, crankshaft. Forged is always a lot more forgiving when it comes to abuse than the OEM parts. That being said anything will break with enough abuse. I've seen a completely forged assembly with ARP fastners rip the top off a piston with 22 lbs of boost and too much timing.
If you search around tho it's been stated on here of guys running 150 shot on stock 350 without issues.
Old Apr 14, 2011 | 12:43 PM
Pab's's Avatar
Car: 1988 IROC-Z
Well im only thinking of a 100 shot so Im sure it will hold on but if there's something i can change might as well.
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
anesthes
Sep 18, 2015 12:34 PM
