turbo tpis guys- throttle body elbows were do u get them
Old Sep 6, 2008 | 11:37 AM
project89's Avatar
im looking to swap my ovalish v6 tb for a tpi tb. now on the v6 tb a 3inch coupler fits it.
what are u guys using for the tpi v8 throttle bodies
Old Sep 6, 2008 | 03:29 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
Re: turbo tpis guys- throttle body elbows were do u get them
I use the 4" to 3" silicone reducer at pepboys
Old Sep 7, 2008 | 02:10 PM
project89's Avatar
how well does it hold? ive seen some guys with oval silicon ones and i figured those would have less of a problem sliping off.
i know with the 3 inch round one on the v6 oval tb i had problems with it poping off till i welded lil nubs around the edge of the tb lip
if theres no issues with the 4inch round one ill get one of those
Old Sep 7, 2008 | 03:28 PM
It has never popped off on me. nuff said.
Old Sep 7, 2008 | 03:29 PM
project89's Avatar
thanks 4 inch to 3 inch reducer it is then,if i do have problems i quess i could always weld a 3/4 - 1 inch wide piece of 4inch aluminum tbing to the front of the tb
this look like the one u got ?
http://cgi.ebay.com/ebaymotors/4-0-t...QQcmdZViewItem
Old Sep 7, 2008 | 06:01 PM
Same size and shape, but I think the ones at pepboys are only 1 ply. I used 3 ply on my first kit, it held just the same. I used worm gear hose clamps.
Old Sep 7, 2008 | 06:22 PM
project89's Avatar
thanks yeah i used some 1 ply ones on my kit i didnt liek them those are the ones i always had issues with
so im deff gonna go withthe 3ply and t bolt clamps this time around
im swaping out my 740 intercooler for a 3inch in and out unit, the volvo was 2.5 in and out the new one is 3inch
so i ran a 2.5 from turbo to intercooler and then 2.5-3.0 on the outlet to run my intercooler to tb pipe
i have single ply coupler on the inlet side of the intercooler and the tb and they always pop off on me
im hoping going to the hks ssqv bov will also help with that since it flows alot more then the blitz knockoff im using now
Old Sep 16, 2008 | 04:30 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
My 4in into 3in coupler never blew off and i ran my setup for over a yr without a blowoff valve. So i wouldnt worry about it.
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
