Project: "Street Lethal", Let's Try This Again....
Old Jan 12, 2009 | 07:17 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
After repeated purchases, followed by unfortunate sales, I finally have the majority of the pieces needed to get this '86 Z28 project in nine second form, hopefully by the end of March. Got my hands on a complete TPI setup from an '86 F-Body, as well as a complete MegaSquirt ECM system. First things first is to pull the carb and convert the engine to fuel injection, and I'll be updating this thread w/pics along the way. Going to be retaining the worked 882 heads, mainly for the desired compression ratio, although they too will be pulled for some additional clean up work. To start of this thread, I'll be working on the TPI system itself. I already pulled out the vacuum ports found on the throttle body, and will be sealing them up with some epoxy. The other three vacuum ports found on the plenum will remain of course, but there will be plenty of port work to follow. For now, here is the basic setup....
Old Jan 12, 2009 | 07:27 PM
Re: Project: "Street Lethal", Let's Try This Again....
I left off a few months back w/pulling out the entire AC setup, while making room for turbo charger. Here is a before and after w/the G20 delete box I eventually went with. All of the unnecessary wiring harness was removed, and those that were retained were shortened for a nice clean look. I'll have more recent pictures up tomorrow....
Size:  38.9 KBName:  G20DeleteBox-2-1.jpg
Old Jan 12, 2009 | 07:38 PM
.... this was just a baseline of what I am currently working with, Click Here, the car now employs an almost complete beige 4th gen interior, and is currently being prepped for Blue Metallic paint. Waiting on a set of 16" Iroc rims, which of course will be fitted with the right rubber;
Size:  35.4 KBName:  CamaroZ28-1.jpg
Old Jan 13, 2009 | 10:59 AM
project89's Avatar
dude u finially got the megasquirt??? get that thing over here and we can have it up and running with the fuel injection in a few hours
Old Jan 13, 2009 | 11:26 AM
NemeSS-TyranT's Avatar
Car: 02 SS
Engine: 408 TT (1108rw-93/m1)6700rpm
Transmission: TH400(slipping)
Axle/Gears: 12bolt/3.42(whines😠)
what turbo?
Old Jan 13, 2009 | 11:38 AM
Originally Posted by project89
dude u finially got the megasquirt??? get that thing over here and we can have it up and running with the fuel injection in a few hours....
Yeah, I finally got my hands on a complete unit. I'm porting out the entire TPI setup first, and I'm still waiting for some of the epoxy to dry. I still have that set of LT1 injectors, just going to have them cleaned for now, but will be upgrading once the turbo is plumbed in. Let me know how much your uncle will charge me for a cage....
Originally Posted by NemeSS-TyranT
what turbo?
T-76....
Old Jan 13, 2009 | 11:41 AM
project89's Avatar
cage kit is what 400 bucks, and for 300 ill weld it in for ya
lol why did u epoxy it? we could have welded the holes up
when u get the heads off let me redo the heads, ill cut them for 2.02/1.60 valves i have a set laying around u can drop in the heads
Old Jan 13, 2009 | 11:48 AM
cage kit is what 400 bucks, and for 300 ill weld it in for ya lol why did u epoxy it? we could have welded the holes up when u get the heads off let me redo the heads, ill cut them for 2.02/1.60 valves i have a set laying around u can drop in the heads....
Good deal on the cage. Was curious to see what it looked like, so I pulled out all three of the vacuum ports, along with the two coolant ports, for a nice clean look. I'm sure the epoxy will hold, but worst case scenario, you could always weld them up later on. The heads will be pulled very soon, if you do it, take your time with them, no rush. Also have a set of BMR SFC's that will need to be welded in....
Old Jan 13, 2009 | 12:21 PM
project89's Avatar
u should ditch those bmr's for a fraction of the cost we could do threw the floor sfc's that will work better
u need those coolant ports. if u block them u cannot run a thermostat. they bypass coolant form one side of the thermo to the other when its closed
Old Jan 13, 2009 | 02:13 PM
u need those coolant ports. if u block them u cannot run a thermostat. they bypass coolant form one side of the thermo to the other when its closed....
.... I epoxied the two coolant ports on the throttle body, not the intake lol.
Old Jan 13, 2009 | 07:30 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Man you sould like me. Get parts, change mind , get rid of em for different parts.
Ive got everything laying around to finish up my turbo motor except for the Turbo and a good waste gate.
Deff. post up some pic's when you start on your headers etc.
Im gonna stick with this kit I have right here and run a S400 if it will fit over there.
http://www.cecoatings.com/images/Car...%20pipes22.jpg
Old Jan 13, 2009 | 07:50 PM
project89's Avatar
robs been on this turbo kick for like 3 years now.
i can personally count 3 v6 cars, 2 or 3 v8 cars,3 turbos.and 2 diff sets of turbo headers he's hand in his hands to build something lmfao
Old Jan 13, 2009 | 09:31 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Oh ya I know. Ive bought parts from him and vis versa.
Same story here...lol.
Old Jan 13, 2009 | 09:50 PM
project89's Avatar
lol i keep telling him, buy the parts put it all in boxes, bring everything over to my shop on a friday,and by sunday he'll get back a turbo car.
lol maybe this time it will get finished,still thinking that v6 car he was gonna do the twins on would have been kick ***. but that 406 hes got now is prime for a turbo
Old Jan 13, 2009 | 10:11 PM
chevyracingrox's Avatar
Car: 88 IROC, 76 Malibu Classic
Engine: 350 TPI, 350
Transmission: 700R4, 4-speed
Axle/Gears: 10 bolt ????
that thing can run! or maybe I'm crazy, but I thought I saw 14.7 1/4 mile. tell me how you like that megasquirt. I'm going to do some more reading up on them.
Old Jan 13, 2009 | 11:25 PM
project89's Avatar
the 14.7 that his car ran was on the carb
its way to small for the motor only a 600cfm carb and it ran that on the primarys only, the rear fuel bowl was bone dry due to a float that was stuck
the 406 with those ported heads should go into the 13's even with only 8-1 cr that the motor has
Old Jan 14, 2009 | 12:05 AM
davtracy's Avatar
Car: 89 camaro rs
Engine: 406sbc
Transmission: 700r4 2800 stall
Axle/Gears: 4.56
Sounds like you guys have quite a bit of experience with hopping up cars. I'm working on a 406 for my 89. I was hoping I might be able to get some help on a cam suggestion. 11:1 comp. Victor Junior intake. 800DP holley, 456 rears, 2800 stall. I run ported vortecs. I was hoping for 475 horse on a flat tappet cam. (All the normal stuff, posi, headers, shift kit...)
Good luck on the fuel injection project.
89 Camaro 350 engine
8.40 in the eighth at 83 mph
256 voodoo cam through the mufflers
Old Jan 14, 2009 | 07:34 AM
I can only imagine what this beast will sound like on boost. who's gonna have the faster car? dave or streetleathal?
Old Jan 14, 2009 | 09:35 AM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I installed and tuned a megasquirt on a mild 305 TBI firebird(zz4 cam with 416 heads), it's a great system. The on the fly tuning is great, took me about 20min to get a pretty good fuel map with someone else driving, that was the first time I ever tuned any EFI. It ran a 14.5 at 94 with injectors going static at 4500.
Old Jan 14, 2009 | 09:36 AM
Originally Posted by TPl383
Man you sould like me. Get parts, change mind , get rid of em for different parts. Ive got everything laying around to finish up my turbo motor except for the Turbo and a good waste gate. Deff. post up some pic's when you start on your headers etc. Im gonna stick with this kit I have right here and run a S400 if it will fit over there....
That is an awesome set of headers Chris! I've been through so many freaking parts its ridiculous lol, but I'm positive that this time it will finally get finished....
the 14.7 that his car ran was on the carb its way to small for the motor only a 600cfm carb and it ran that on the primarys only, the rear fuel bowl was bone dry due to a float that was stuck the 406 with those ported heads should go into the 13's even with only 8-1 cr that the motor has
That is the honest truth about the primaries, but I didnt't want to post that in the description on youtube, because it would have sounded like I was making excuses. When we adjusted the float, with the secondaries finally squirting, it was impossible to hook. Do you remember Dave lol, the car smoked the tires up until the 1/8th mile both times....
I can only imagine what this beast will sound like on boost....
More than likely like this, Click Here....
Hmm...
Old Jan 14, 2009 | 09:48 AM
lol maybe this time it will get finished, still thinking that v6 car he was gonna do the twins on would have been kick ***. but that 406 hes got now is prime for a turbo....
That was such a nice '92 Firebird too, the township was complaining about the cars though, so I had to let it go. I really wish the '91 Formula would have worked out to tell you the truth....;
Old Jan 14, 2009 | 11:12 AM
project89's Avatar
+1 me and rob installed my megasquirt in a few hours
then we had the car up and running n/a in 20-30 mins.
was also my first install and tunning attempt at efi
megasquirt just works lol
rob should have the fatser car lol 9 second time slips shouldnt be an issue for him,
lol i might have to change his wastegate spring to a 3 psi spring or losen one of his coupler clamps when hes not looking.cause i know were gonned end up running each other down the track
Old Jan 14, 2009 | 06:38 PM
jonarotz's Avatar
Car: 91 Z28
Hmmmm those turbos look really familiar. I am glad you are getting back into the turbo project. You will not be disappointed. I am absolutley hooked now.
Attached Thumbnails Project: "Street Lethal", Let's Try This Again....-100_0151.jpg
Old Jan 14, 2009 | 07:47 PM
^ Very nice, the engine bay looks awesome....
Old Jan 14, 2009 | 08:00 PM
lol i might have to change his wastegate spring to a 3 psi spring....
Dave, you wanna take a ride to the shop tomorrow? I want to modify the fuel rail a little, as I'm planning to plumb it on the opposite side. I'm going to use the cold start injector area as the supply line, and cut the return right by the regulator and re-route to follow along side of it. You'll just have to weld the front of the passenger side fuel rail shut. Here's the concept....;
Old Jan 14, 2009 | 08:31 PM
project89's Avatar
yeah thats nto a problem but u know we can tap and drill that thing anywere u want the fuel inlet and outlet. might be better off waiting till its on the car to do it
Old Jan 14, 2009 | 08:36 PM
....might be better off waiting till its on the car to do it
.... too late lol, I went at it with a hacksaw. Was going to simply turn the regulator housing around, but it won't seat right, so I'm going to do it the same exact way in the pics. Going to run braided line all the way back to the sending unit in the tank and tuck them completely away from the exhaust, by the way, do you have a flare gun? I misplaced mine lol.
Old Jan 14, 2009 | 09:12 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You could do something like this..
my server is down right now. But I have pic's of a tpi rail modified like your talking about also.
Old Jan 14, 2009 | 09:16 PM
project89's Avatar
flare tool for what standard fittings or a flare tool for doing an lines?
well it dont matter lol i have both
Old Jan 15, 2009 | 10:06 AM
You could do something like this. my server is down right now. But I have pic's of a tpi rail modified like your talking about also.
Yeah, please Chris. Let me see the modified rail whenever you get the chance. I just finished making a block off plate for the EGR to boot, so I should have a few pictures up soon....
flare tool for what standard fittings or a flare tool for doing an lines? well it dont matter lol i have both....
Dave, I forget, what size is the fuel delivery line, as I need a fitting to replace the cold start injector fitting (it's too small)....
Old Jan 15, 2009 | 10:13 AM
project89's Avatar
im not sure on the tpi rail,u still want to head over to the shopp today??
Old Jan 15, 2009 | 10:48 AM
Yeah, I'll take a ride. Just waiting for the damn snow to clear up first lol....
Old Jan 15, 2009 | 10:49 AM
project89's Avatar
dude its liek 1/2 inch of snow rofl.
Old Jan 15, 2009 | 11:00 AM
dude its liek 1/2 inch of snow rofl....
These freaking 3rd gens slip and slide with just the thought of snow....
I'll call you in a few minutes....
Old Jan 15, 2009 | 11:01 AM
project89's Avatar
bah at slip and slide, its called drift practice lmfao
lol throw some cinder blocks in the trunk and it will be all good
Old Jan 15, 2009 | 08:17 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Old Jan 15, 2009 | 08:19 PM
The fuel rail is almost done. In the first picture, you can see where Dave welded the fuel inlet in the front of the rail completely shut. The new location will be on the back where the cold start injector line was plumbed. Also, I didn't trust the return line coming from the regulator, a little too loose for my taste. Tomorrow I'm going to tap the hole and put in the proper fitting. Don't mind the pics, the weld will be smoothed, and the rail will be polished...;
Thanks Chris, that's exactly what I'm looking to do. How is that regulator w/boost....?
Last edited by Street Lethal; Jan 15, 2009 at 08:22 PM. Reason: Automerged Doublepost
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Doobie52
Sep 11, 2015 06:19 PM
