Modifying wet nitrous kit to dry?
Old Jan 27, 2009 | 09:57 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Is it possible to remove the nitrous hose on the bracket and lengthen and spray a dry shot into my blower? I guess thats not really a "dry" shot, but you know what I mean.
Wet kits are cheap, and I can't find any decently priced dry kits. Only shooting a 50-100 shot. Probably just 50 though.
Old Jan 28, 2009 | 12:54 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Modifying wet nitrous kit to dry?
How are you compensating for the extra shot then? With a dry shot you need to dump the extra fuel somehow.
Old Jan 28, 2009 | 12:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Can't really go dry with a carb.
Old Jan 28, 2009 | 11:03 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Sure you can. Some blower manufacturers don't like you to spray pre-blower, but it's possible. The blower becomes more efficient with the increase in air density. Just make sure your AFR stays where you want it.
Old Jan 28, 2009 | 11:38 AM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I would leave the fuel side of the bracket on, just remove the nitrous side and relocate it. Spray the fuel under the carb, spray the nitrous into the blower.
I know nothing about a n20 system though, and I don't know how hard it would be to hook up a nitrous jet to a custom line.
Old Jan 28, 2009 | 06:18 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Using the spray-bar (plate system) for fuel without the nitrous flow is a no-go, if that's what you're planning to use. It will just shoot streams of liquid fuel into your manifold and it will become very unhappy with that.
All you need is a plain N2O nozzle to go on the end of your line. The jet will fit between the nozzle and line. Your line will just need the correct size adapter for the nozzle if needed.
Old Jan 28, 2009 | 06:22 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
you should really contact a nitrous company!
http://www.nitrousoutlet.com/index.asp
http://www.nitrousexpress.com/
Old Jan 28, 2009 | 08:01 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Does the nitrous mix with it and atomize it? Straight fuel wouldn't work too well with how cold my intake is gonna be. E85 and single plane with the separated coolant runner.
So if I wanted to spray a shot into my blower, I'd have to buy a specific system?
Old Jan 28, 2009 | 08:33 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
No you just need a bottle, a solenoid & relay, a couple of lines, a nozzle & flare-jet, and a button.
A small 50 - 100 hp shot of N2O does't require a tremendous amount of extra fuel. Once you have your carb converted for E85 take a look at where your AFR is. It might be enough to cover it.
You'll be looking for AFRs between 6.5:1 and 8.5:1 @WOT.
If you're on the richer end of that or around 6.0:1 it will probably cover the 50 shot.
Here's a link with some E85 info.
http://www.eco-flex.us/pdfs/E85.pdf
Old Jan 28, 2009 | 09:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The nitrous spraybar is located above the fuel spraybar so that the 1600 PSI nitrous stream will atomize the fuel as it dribbles out under 6 PSI or so.
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
