nitous purge line
Old Apr 30, 2009 | 08:39 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
nitous purge line
where and how can i make a purge line longer? i bought the n.o.s purge valve kit and the line is wat to dam small. anybody have ay ideas? i wanna use steel or copper not rubber.
Old Apr 30, 2009 | 08:43 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: nitous purge line
Old Apr 30, 2009 | 09:59 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i just used regular 3/16 brake line from the parts store
Old May 1, 2009 | 07:05 AM
50bmgshooter's Avatar
pretty sure that the purge line is the same as the line for a oil psi gauge. just use the copper one
Old May 1, 2009 | 07:10 AM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Old May 1, 2009 | 11:22 AM
Engine: 355
i am at work and forgot the line, summits saying its 1/8 line. i have a -4n purge kit. which line size do i use
Old May 1, 2009 | 12:14 PM
CBR1000RR's Avatar
Car: 91 Z28
Engine: 355
Transmission: 5 speed
Axle/Gears: 10 bolt 3.73's
You can get 1/8" copper tubing at any home improvement store. You can also find it at most auto parts stores, it's used to install mechanical pressure gauges.
Old May 1, 2009 | 12:20 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
use whatever the compression fitting you slide the line into is.
83 Crossfire TA
Jan 3, 2016 01:26 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Racerx974
Sep 19, 2015 10:16 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
