suggestions for custom chip
Car: 86 Iroc-z
Engine: worked 350tpi
Transmission: built 700r4
Axle/Gears: auburn pos 4-10
Im finally ready for a custom chip to be burned for my 305 tpi supercharged iroc what is the best company to go with? tpis, fast chip any suggestion?Best hp for the money thats what im lookin for
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: suggestions for custom chip
You also don't specify what ECM, or if you are using an FMU and BTM, or you expect it to 'just work'.
-- Joe
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Good luck
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 86 Iroc-z
I understand doing a chip by mail order may not end up being perfect it should be done on a dyno but thats not in reach, tpis or other companys go through everything that you have done and need done so at least it will be alot better than runnin a stock chip with too many mods done i gotta start somewhere. Thanks for the tip ill call blowerworks and see how that goes.
The reason, it because I have not try my yet and I am in the middle of working on my car. Greg, gave me some good advices what to look out for and what works best for the motor HP with supercharger.
Thanks.
Car: 86 Iroc-z
Hey everyone i ended up giving Greg fom Blowerworks a call, he ended making me a custom chip and went with his mass air flow meter which cured the check engine light and the chip is great runs alot better now.So thanks for the advice everyone glad i went with Blowerworks
What kind or make chip and MAF did you get from him?
I got the Eprom Multiple chip and the MAF HPX from him and much more.
Please let me know how it runs so far and how much did it improve from stock parts? I havent try my yet hopefully soon.
Thanks.
Car: 86 Iroc-z
Greg had burned a custom chip for all the mods i had done to my motor, to increase fuel for the bigger injectors,set the idle diff and timing curves for the charger.The mass air that i had got from him is machined aluminum, he changes the value or grams per second in the chip to work with the mass air so no more check engine light.He gived detailed instructions in the computer harness you swap one green wire to an empty port so the new chip sends the new signal to the green wire.Was the easiest thing i have done on my car and it works excellent.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I didn't want to have my car sit while I was trying to learn how to tune it after my H/C/I swap. I got a chip from Fast chips and it was night and day. It ran way better. But we all know you're not going to be spot on with a mail order. Once I was finally educated enough to burn my own chips, I asked Ed Wright if he would send me my bin file so I can "fine tune" off of it. We discussed earlier how it takes hundreds of hours to get a perfect tune, and how his mail order would just get it running decent. Well he flipped out on me for some reason and accused me of wanting the bin so I can give it away for free on the internet? The chip I paid $350 for...to give away for free on the internet? lol
We talked it out, and he burned me a few other chips with no problems and was fast. While the car ran fine, once I data logged it I seen a idle BLM of 108. So needless to say it needed fine tuning. I got my idle BLMS to around 120 now. Pull some fuel here, add some there, added some timing at WOT, and it was even better.
But overall, he was a good guy, and was fast.
Hotrodboba400
Dec 10, 2019 07:07 PM
