Adding a supercharger to a high compression engne...
Car: 1988 Camaro(92 Z28 clone)
Engine: Forged 383, AFR 195 419/430@wheels
Transmission: Monster 700R4 Yank 3600 stall
Axle/Gears: 9in Detroit locker-3.90's,35 spline
Well, first let me start off by saying my car made 420HP and 430TQ to the rear wheels with a T5 and my 383 stroker N/A. I have since switched over to an automatic, and I understand that my horsepower will drop off due to the increase rotation weight of things like the converter etc. I am fully expecting a 50-60 horsepower loss. To compnesate for this loss, I was thinking about adding a Vortech S trim or some other comparable belt driven centrifugal superchager at a modest 5-6PSI. The only problem is that my engine currently has about 10:1 compression. Is it feasible to run a small amount of boost with that high of compression just to make up a little power, or is it completely unadviseable? Thanks for any information or opinions on this!
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: Adding a supercharger to a high compression engne...
you could install real thick head gaskets to bring the compression down some. other than that, you'd really have to change out the pistons for lower compression.
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Are you running EFI? You could richen the A/F ratio and pull some timing to make it work. Not an ideal solution, but it will get you where you want to go.
Is this advisable? I wouldn't do it.
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I bet you lose around 40rwhp by going to the auto. Blowers are put on stock LSx series engines that have 10.x to 1 ratio's, keep the boost reasonalbe and run MLS head gaskets and it should be feasable. Do you have aluminum heads, head studs, etc? Good fastners will definitely help.
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I don't see a problem with 6 psi on a 10:1 motor. It wouldn't be the ideal configuration and gives you less margin for error, but certainly has been done. Look at the various kits for LT1's and LS1's running over 7psi on stock engines no problem.
Just be conservative with your timing and AFR's and have fun.
Car: 92 Z28
Engine: Boosted LSX
Tons of people running more then 6psi on 10+ comp.
Good read and links over here
http://www.yellowbullet.com/forum/sh...d.php?t=162651
Car: 92 trans am clone
Engine: LO3
You could definetely do 6-8psi on 10:1 Im running 9.5:1 with 14psi just dont forget a nice and big intercooler and a great tune.
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
look in to race gas.
110 octane will let you do a lot more
it can be done. it has been done. and it will be done again and again. works good with no problems. and can be done with 93 octane fuel with correct timing set up.
Car: 92 Z28
Engine: Boosted LSX
The key to anything is all in the TUNE ! keep it out of detonation. watch how aggressive you get with your timing.
armybyrd
Sep 15, 2015 06:06 PM
101, 350, adding, change, compression, engine, good, high, nitrous, run, supercharge, supercharger, superchargers, supercharging, things
