NOS 05151 kit..microswitch location
Old Feb 19, 2010 | 08:59 PM
joe2844's Avatar
Car: 1991 Camaro Z28
Engine: Carb 5.3
Transmission: Th350
Axle/Gears: Moser 12 bolt, 4.11 gears
ok guys jus bought a nitrous kit. got everything installed except the micro switch. can you guys post some pics of how you mounted it so that its sturdy and reliable?? the instructions weren't so clear on how to do so. thanks!!
oh and where did you guys mount your bottles??
Old Feb 19, 2010 | 09:04 PM
Drew's Avatar
Re: NOS 05151 kit..microswitch location
I spent about an hour looking at the supplied bracket, and then I went down to the hardware store and picked up a piece of aluminum angle. I drilled one hole in the angle and put it under one of the throttle body bolts. Then I cut another rectangle of aluminum and mounted the switch to it. Finally I bolted that piece to the angle. It took a little cutting, grinding, and drilling, but it worked.
Sorry no pics, it's been a few years and at the time I wasn't really documenting.
Edit, found one of my bottle mount. lol
Old Mar 24, 2010 | 11:54 AM
joe2844's Avatar
Engine: Carb 5.3
Transmission: Th350
thought id show ya what i ended up doin. carb stud works great.
Old Mar 24, 2010 | 12:06 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
if you ever get a controller alot of them have WOT tps switches already in the box, just tap into the blue tps wire and read voltage at WOT
Old Mar 24, 2010 | 07:26 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
i actually put mine under the dash and the top of the pedal hits it when you go WOT
Old Mar 24, 2010 | 10:56 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I used the HSW (harris speed works) LT1 throttle body bracket with switch. Its like 20 bucks and bolts to the bottom TB screw on TPI/LT1 style TB's. My holley throttle body wouldnt trigger the switch with the throttle linkage lever so i drilled a hole in the lever arm, and put a small screw so that it would trigger the switch at WOT.
Old Mar 28, 2010 | 09:44 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I've got their bracket, solid made. www.jimmy-jams.com
Old Mar 28, 2010 | 09:59 PM
joe2844's Avatar
Engine: Carb 5.3
Transmission: Th350
nice i like that jimmy-jams setup. bracket and the ashtray/shifter switch plate are going to be in my posession soon
Old Mar 30, 2010 | 05:06 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
this one is a little cleaner IMO
http://www.nitrousoutlet.com/catalog...1&product=3448
Vintageracer
Sep 24, 2017 12:34 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
6998poncho
Sep 25, 2015 02:56 PM
tonys91rs
Sep 2, 2015 07:07 PM
