How much power?
Old Mar 7, 2010 | 08:20 PM
ProjectBird85's Avatar
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
How much power?
Just curious since my ride wont be dynoed till the end of the week what kind of numbers I could expect so my expectations aren't too high. Im guessing somewhere in the 500 HP range, the supercharger Im guessing is running stock boost 8 lbs? Anyone know how much more boost I can add without forged internals?
My mods are as follows:
SBC 355ci
Comp blower cam
KB Hyper Pistons
Eagle Rods
Federal Mogul Main and Rod bearings
Chromemoly pushrods
Comp Blower Cam
Federal Mogul Oil Pump
TCI Balancer
World Sportsmen 2 heads
4-Core Aluminum Radiator
Procharger Small Block Chevy kit with P600B, Polished
Upgraded mechanical fuel pump
Modified Holley 650 CFM
B&M Th350
B&M Shift kit
B&M Torque Converter
10 bolt rear
Richmond 4.10s
Auburn Posi Unit
Hedman Headers
3 Core intercooler w/L98 waste gate/surge valve
MSD 6AL-BTM
Griffin 4 core radiator
True dual exhaust w/flowmaster super 44's
Old Mar 8, 2010 | 10:54 AM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: How much power?
My buddy's 355 w/ 195 elim afrs made just over 400rwhp on 6 lbs through a 700r4 and a 12bolt. The F1A was pullied to 15lbs, but it had leaks. So the Charger was eating some of the power. Also I would say the tune isn't 100% dialed in.
I'd say 500 is a tad lofty for a RWHP number, at the crank I'd say possibly.
Old Mar 8, 2010 | 12:57 PM
4playta's Avatar
Car: 1984 Trans Am
Engine: Built chevy 350
Transmission: TCI Built 700r4
Axle/Gears: 3.73 posi 10 bolt
Re: How much power?
Isn't a 650 carb too small for that setup? I realize that it is a blowthrough but will it supply enough fuel? My 350 in my transam is moderately built, afr 210 heads, 10:1 pistons, cam is 240-245 the lift is .504-515 and I needed a 750dp because a 650 was choking it.
Old Mar 8, 2010 | 01:40 PM
Re: How much power?
yea at 8psi you should be moving approx 870 cfm of air. not sure what the 650 is rated at under pressure. The engine alone at 6k is moving approx 560cfm. The 650 might be a bottle neck, but that just means your power can only go up!
Old Mar 8, 2010 | 01:49 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Re: How much power?
Massive set-up man. I'd love to see 1/4 mile numbers
Old Mar 8, 2010 | 07:01 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Re: How much power?
My virtual butt dyno says.. Assuming a good tune and 9:1 compression, the engine is probably making somewhere around 330 to 350 crank hp before boost. So if we use 340 hp as a base, and add 8 lbs of boost, minus about 20% for inefficiencies and parasitic supercharger drive loss, I'd expect to see 450 to 480 crank hp out of this setup. Accounting for drivetrain losses of 15%, I'd bet right around 400 rwhp.
Old Mar 9, 2010 | 08:24 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: How much power?
with that amount of power your going to go through your 10 bolt pretty quick
Old Mar 11, 2010 | 06:50 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: How much power?
Not necessarily
Old Mar 11, 2010 | 08:03 PM
Car: 1985 Trans Am
Re: How much power?
Well she's in the shop, Im hoping to get the call sometime tomorrow afternoon to go see her get dynoed. She's getting the MSD 6al BTM installed along with new dynomax ultraflo mufflers. Before I up the boost I have to get my intercooler put on as well. As for 1/4 mile I would expect mid 11's or so. She's very fast pulls harder than anything I've been in.
Old Mar 11, 2010 | 09:03 PM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Re: How much power?
nice.....keep us posted.
Old Mar 11, 2010 | 09:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: How much power?
Nice got any pics?
Old Mar 11, 2010 | 10:04 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: How much power?
Not necessarily
My 10 bolt is guaranteed to over 600HP with an Eaton Posi and 32 Spline stock truck axles
Old Mar 12, 2010 | 08:28 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: How much power?
how can it be guaranteed??
Old Mar 12, 2010 | 09:57 AM
Gregzz4's Avatar
Re: How much power?
It was built and installed at a place that only does rearends, specifically IWE Rear Ends Only.
I told them I might put a supercharger on it and take it to 520HP.
They said it could handle 600HP easy and gave me a 1 year, break it if I can warranty.
Old Mar 12, 2010 | 10:30 AM
Re: How much power?
Do you have an aftermarket housing? Because 450 is the limit on a welded stock housing.
Old Mar 12, 2010 | 10:31 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: How much power?
Your talking about a truck 10 bolt being 8.2" i believe... we are talking about 26-28 spline 7.625" 10 bolts in the fbody's. I dont believe there is a 32 spline option for a fbody 10 bolt
Old Mar 17, 2010 | 09:00 PM
Car: 1985 Trans Am
Re: How much power?
Well she fell flat on her face today, not sure why she only made 300 WHP at like 4-5 lbs of boost. Also at around 4500 rpm my power curve was going down as well. They said it should have made easily 450+ Im loosing boost somewhere
Old Mar 17, 2010 | 09:27 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Re: How much power?
Did they wide band it during the pulls? Curious how you AFR looks.
What kind of cam specs and what lobe separation? Oops nevermind, I see you have a blower cam.
Old Mar 17, 2010 | 09:29 PM
Car: 1985 Trans Am
Re: How much power?
They said the A/F was good, it's carbed so not sure how much that will help. I dont know my cam specs the build sheet I got doesnt tell me. If it's the basic comps blower cam the specs are
Brand
COMP CamsManufacturer's Part Number
12-404-4Part Type
CamshaftsProduct Line
COMP Cams Blower and Turbo CamshaftsSummit Racing Part Number
CCA-12-404-4
Cam Style
Hydraulic flat tappetBasic Operating RPM Range
1,800-5,800Intake Duration at 050 inch Lift
222Exhaust Duration at 050 inch Lift
226Duration at 050 inch Lift
222 int./226 exh.Advertised Intake Duration
268Advertised Exhaust Duration
276Advertised Duration
268 int./276 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.464 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.464 in.Valve Lift with Factory Rocker Arm Ratio
0.464 int./0.464 exh. liftLobe Separation (degrees)
114Intake Valve Lash
0.000 in.Exhaust Valve Lash
0.000 in.Computer-Controlled Compatible
YesGrind Number
CS 268AH-14Quantity
Sold individually.
Old Mar 17, 2010 | 10:47 PM
daverr's Avatar
Re: How much power?
for what u have and the amount of boost its about right. did u play with the ignition timing??
turn up the boost u will be happier.
Old Mar 18, 2010 | 07:31 AM
Car: 1985 Trans Am
Re: How much power?
They adjusted the timing with a light which was way off. I had to turn the distributor some because it was stalling. They retarded the timing some to accommodate the boost. I'm just not sure why it's not making the proper boost.
Old Mar 18, 2010 | 08:24 PM
Car: 1985 Trans Am
Re: How much power?
Well I think they didnt know what they were doing on the dyno. I took it out today on an open stretch and matted the gas to WOT and I made consistent 8-9 psi, couldnt see my RPM because my tach doesnt work so installing the monster tomorrow. I think they didn't make WOT and only 2 of the 4 barrels were opening, so It's about 450 horse at the wheels at 8 psi
Old Mar 19, 2010 | 08:40 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
Re: How much power?
If they didn't know what they were doing, I'd want to verify the tune. Double check that the timing and a/f ratio are safe before you risk breaking things.
Old Mar 19, 2010 | 09:02 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Re: How much power?
Well the AFR doesn't care if you're carb'd or fuel injected but a boosted engine certainly cares what the AFR is. If you get into the mid 12's or higher at full boost, at some point the car will fall on its face. If you get below the upper 10's you'll start losing power as well. Do you have a wide band O2 gauge on the car?
As for your 300 rwhp though, if you were only making 4-5 psi then that number isn't so bad. That puts you around 300 crank hp + a 25-30% power increase. It is interesting though that you're making the 8 psi driving it around but made less on the dyno.
Old Mar 19, 2010 | 03:32 PM
Car: 1985 Trans Am
Re: How much power?
I dont have a wide band. The air/fuel is comfortable at around 12 which according to procharger is good. What I think is they didnt hit WOT they got 4lbs of boost at 4500 with 2 barrels open at the carb. I've been able to hit 8-9lbs driving it around matting the gas to the floor. Guess I'll find out when I get to the track next week.
Old Mar 19, 2010 | 04:54 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Re: How much power?
Yeah you never know.. a certain shop in my area has been known to skew dyno results lower to make other people's work look bad and then they try to sell the customer on their services. Of course when they dyno their own work it looks perfect.
Old Mar 19, 2010 | 05:24 PM
Car: 1985 Trans Am
Re: How much power?
Yeah who's to say they didnt do the dyno right to have me spend more $$$$ for them to find something wrong. I wish there were more speed shops here with a dyno
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
