FMIC Installs
Old Mar 18, 2010 | 08:26 PM
ProjectBird85's Avatar
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
FMIC Installs
I want to get my intercooler installed but I'd rather do it myself. Are there any threads dedicated to this? I have the Procharger 3 core intercooler. I'm sure I'll have to take my front bumper cover off, I am a visual learner so any help would be awesome
Old Mar 22, 2010 | 12:18 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: FMIC Installs
The procharger 3 core is designed to be mounted Horizontal. I have heard that you can mount it vertical. Me and a buddy mocked it up but which ever inlet/outlet you put towards the top exits right at the high beam, so I am not sure how you would connect the piping. The offset inlet/outlet doesn't make it easy. To really do it you would need to get an intercooler with the inlet/outlet on the same side.
We put this one in without removing the bumper cover. just the plastic ducting behind the bumper and the plastic piece that goes from bumper to the radiator support.
He used an intercooler similar to the one in first few posts of this thread and mounted it similar, just without tearing the bumper off.
https://www.thirdgen.org/forums/powe...oler-idea.html
it's a Godspeed, he got it off Ebay. 3"inlet/outlet I forget the exact diameters maybe 30x12x3. Beater79TA is his name on here. PM him and he can tell you exactly.
Old Mar 22, 2010 | 05:05 PM
Blownz28man's Avatar
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
Re: FMIC Installs
I bought mine off ebay fro about $140. It 31x12x4. I'm gonna notch the metal bumper support and put it up in there. Heres a few posts from ls1tech
http://www.ls1tech.com/forums/conver...r-project.html
and
http://www.ls1tech.com/forums/multim...rdgen-ls1.html
Old Mar 22, 2010 | 10:38 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: FMIC Installs
i have a couple pics. posted on my turbo build thread.
Old Mar 23, 2010 | 09:48 AM
KS91Z28's Avatar
Re: FMIC Installs
I mounted my ProCharger 3-core intercooler vertically using all the tubes supplied by ProCharger. I just had to get 1 extra rubber 90 to point the outlet of the intercooler down. (I did have to do some trimming of the bumper support beam though.)
Old Apr 1, 2010 | 06:48 PM
Car: 1985 Trans Am
Re: FMIC Installs
Does anyone have pictures of there trans am install? I have the procharger 3 core intercooler with the inlet down and outlet up. There's no where to mount this thing. I was trying to figure this out for an hour and ran out of daylight.
Old Apr 1, 2010 | 06:52 PM
Twin_Turbo's Avatar
Re: FMIC Installs
Old Apr 1, 2010 | 07:00 PM
Car: 1985 Trans Am
Re: FMIC Installs
So the 2 mounting brackets on the side is where I was trying to figure where they could go. Also I have no room for intercooler pipes other than re-locating the battery and mounting them through the battery tray on both sides. so frustrating
Old Apr 1, 2010 | 07:13 PM
Twin_Turbo's Avatar
Re: FMIC Installs
That's what I did there too, the pipes are too large, they will not fit between the fenders and front frame structure. It simply can not be done, this was not designed for a firebird, or at least not a late model one.
Here's a bunch of pics of how I did it. I cut up a set of old pipes from the same set and modified them to fit, the pipes were later powdercoated. The fender support brackets were also modified, as was the hood latch support bracket (bottom trimmed down) and all powdercoated after. The 2 trays on the side of the car were cut, the evap canister was moved by cutting new holes for the retainer plugs (white square plugs)
The lower GFX panels had to be cut, one side the bumper was cut, the other side has the "scoop" modified. There's no other way it would fit. All in all it came out pretty clean. There was no getting around cutting and modifying.
Old Apr 1, 2010 | 07:14 PM
Twin_Turbo's Avatar
Re: FMIC Installs
Old Apr 1, 2010 | 07:48 PM
Car: 1985 Trans Am
Re: FMIC Installs
Right now my big issue is I dont have access to a lift and it's down right a pain in the @$$ to do it outside with the front jacked up laying on the ground. I guess the big ? would be is it worth it to add the intercooler now or wait till winter when I yank the engine? I do on the other hand want to add some pipe so I can use my surge valve though.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
