Stock Neon SRT-4 Turbo
Old Aug 31, 2010 | 04:40 PM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Quick question. Is implementing the stock turbo charger from a neon srt-4 doable? Or practical?
Old Aug 31, 2010 | 04:59 PM
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
Re: Stock Neon SRT-4 Turbo
iirc the srt4 turbo is not removeable from the manifold...of course im sure there is a way. i asked the same question a long time ago and i think everyone said it would be to small of a turbo even for my v6 motor
Old Aug 31, 2010 | 05:08 PM
Axle/Gears: Stock
My buddy just did a turbo swap on his SRT so he just has it laying around now thats why I ask
Old Aug 31, 2010 | 05:12 PM
Pillsbry10's Avatar
https://www.thirdgen.org/forums/v6/3...turbo-3-a.html
Old Aug 31, 2010 | 05:20 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
It's doable, but not worth the effort. Too much heat would be generated from such a small turbo trying to keep up with an engine much larger to that of an SRT4....
Axle/Gears: Stock
Didnt really get a definitive answer there
Old Aug 31, 2010 | 05:22 PM
Axle/Gears: Stock
So there would be no gains? Also what about the turbo on my cobalt? It is a larger flowing K04 Borgwarner turbo. It pushes 260HP stock with 15PSI. I could acquire a second one of these
Old Aug 31, 2010 | 05:28 PM
No real gains, and not worth the effort....
Also what about the turbo on my cobalt? It is a larger flowing K04 Borgwarner turbo. It pushes 260HP stock with 15PSI. I could acquire a second one of these....
It pushes that much boost pressure through a smaller engine. Once you substantially increase the diameter of the intake tract, as well as cubic inch displacement, that turbo will simply run out of steam. You'll make boost, yes, but the turbo will be maxed out, with the byproduct being heat. Twins could definitely be a consideration though....
Pillsbry10's Avatar
i would say no on the srt4 turbo, to small to much effort as stated
the cobalt one may be better but its still on a much smaller motor(which motor are you trying to turbo?)
you might be better off getting a knock off ebay turbo, they are cheap and lots of people have had good luck with them. of course some of them are horrible to i think its mostly luck getting a good one. im running one and got lucky with a good one
Old Aug 31, 2010 | 05:33 PM
Axle/Gears: Stock
Trying to turbo the LO3
Old Sep 5, 2010 | 04:34 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
try looking for some holset turbos off of cummins diesels. my hy35 looks pretty big. hx35 is more something for a v8 car.
Old Sep 6, 2010 | 12:23 PM
DIGGLER's Avatar
i believe the srt-4 turbo has an exhaust housing incorporated into the exhaust manifold bolted to the head. you can remove the guts of the turbo, but in order to use it on another car you would need to come up with an exhaust housing with a t3 flange or whatever.
(im 90% sure on this- my PT cruiser is this way, and they are basically identical engines aside from the intake manifold.)
Old Sep 6, 2010 | 01:05 PM
roachjuice's Avatar
Car: 86 Omni GLHT
Axle/Gears: 3:85
besides. the srt turbo is waaayyyyyy too small for a v8. hell its too small for the srt 2.4
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Genopsyde
Oct 7, 2015 08:35 PM
camaro71633
Sep 1, 2015 10:24 AM
