Nitrous help?
Old Oct 1, 2010 | 10:57 PM
COTY'S IROC-Z's Avatar
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Nitrous help?
i just bought a nitrous wet kit.. i need help wiring it up! lol i have a nitrous express 10lb bottle with an zex box i gess its a silnod.. whats the red, black, and white wire's for on the zex box an how do i huck them up??? ....on the zex box it got a fuel in an a fuel out what that for an how do i huck it up??? ... an a nitrous in an out an how do i huck the up?
Old Oct 1, 2010 | 11:21 PM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: Nitrous help?
red wire from zex box goes to SWITCH supplied 12 volts+
white wire from zex box goes to light blue wire on TPS{middle wire of the 3 wire connector on tpi cars}
black wire goes straight to ground.
fuel line from fuel rail/external fuel supply goes to FUEL IN port on zex box
Ntrous feed line FROM the bottle, goes to the NITROUS IN port on zex box
Nitrous out goes to the nitrous side of the nitrous nozzle
Fuel out goes to the fuel side of the nitrous nozzle.
Old Oct 1, 2010 | 11:32 PM
ProjectBird85's Avatar
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
Re: Nitrous help?
http://www.zex.com/Base/Instructions/ZEX140.pdf
This should answer all your questions
Old Oct 2, 2010 | 01:12 AM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: Nitrous help?
i dont have a fuel injection car mine is card?? how would iwire it for it??
Old Oct 2, 2010 | 01:27 AM
On Probation
Re: Nitrous help?
it will not work then...UNLESS...
you fabricate a TPS to go on to your carbs throttle shaft, it would have to be able to have the correct low voltage at idle, and 4+ volts at wot
You simply CANNOT just put 4+ volts to the white TPS switch on the zex unit, it looks for the voltage sweep from idle, to WOT, inincremental steps/voltage before it triggers the solenoids to open..
it does this to help eliminate the possibility of a faulty tps/bad TPS ground, which will cause HIGH tps voltage, and would trigger the system to spray on its own.
If i were you, id sell the zex box to someone needing/wanting it for EFI..and use the money to just buy real solenoids.
Old Oct 2, 2010 | 10:53 AM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: Nitrous help?
cant i just put it on a buttin
Old Oct 2, 2010 | 10:55 AM
Car: 1985 Trans Am
Re: Nitrous help?
I wouldn't recommend that. Just buy the solenoids from NOS or ZEX and be done or sell that kit and buy another wet kit. If your on a cab set up you will need to buy a carb plate.
Old Oct 2, 2010 | 01:19 PM
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
Re: Nitrous help?
i got the pate
Old Oct 2, 2010 | 02:03 PM
On Probation
Re: Nitrous help?
READ what i wrote, and then READ it again.
Old Oct 2, 2010 | 07:37 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Nitrous help?
You need a different setup that box is for TPI. You need to get a better setup for a carb or a kit for a carbed motor. Im sure there is a way to hackjob it in there but its not the right way. Buy the right stuff and install it the right way it will be a lot less of a headache
Old Oct 2, 2010 | 09:06 PM
Car: 1985 Trans Am
Re: Nitrous help?
I have a kit that was for FI but it has the solenoids and my carb plate has 2 ports for fuel/nos and I have correct jetting. Easier then dealing with hacking
Old Oct 2, 2010 | 09:54 PM
Car: 1985 IROC-Z
Engine: 355
Re: Nitrous help?
Right he could get the correct stuff to hook it up orrr he could get the correct kit being he is unsure of how to install this with his carb.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
