can i run my turbo drain in to my valve cover?
Old Oct 11, 2010 | 07:33 PM
mog10's Avatar
can i run my turbo drain in to my valve cover? seems like a shorter path i dont see why not but i would like to get some feed back thanks
this is what im working with
Old Oct 11, 2010 | 09:02 PM
BANDITSBC's Avatar
Car: 90 gta
Engine: 5.slow turbo
Transmission: tremec tko
Re: can i run my turbo drain in to my valve cover?
it looks like you could, 2 45degree fittings and 1/4 inch length of hose. it may work.
it looks like it may be a bit awkward but i think you can do it, a 45 off the turbo and a bung in your valve covers
Old Oct 15, 2010 | 06:05 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I've read of problems with flooding the valve cover, sealing the valve cover and using a crank case evac system on the opposite side might help?
Old Oct 16, 2010 | 01:43 AM
The_Punisher454's Avatar
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
By looking at the pictures I can see why you would be tempted to return to the valve covers, but if it were me I'd feel a whole lot better returning the oil to the pan.
Sometimes the oil from the turbo is a bit foamed up. The long vertical return line will help reduce this and the large volume of oil splashing around in the pan will help dissolve any foam instantly. In the valve covers you only have a small volume of oil flow to help.
Old Oct 16, 2010 | 01:46 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
You might also want to consider a tapped fuel pump block off plate. Many people do that and its much closer to the oil pan and pretty cheap to make... if you're not running a mechanical fuel pump that is...
Old Dec 30, 2010 | 10:19 PM
bduffey723's Avatar
Car: not a camaro anymore
im in the midst of my tt install and and wondering if i could do the same because i relly dnt want to have to drop the oil pan. what if i run it from the turbo to a catch can and then into the valve covers? or is there anywhere else besides the oil pan u can return them to?
Old Dec 30, 2010 | 11:31 PM
mog10's Avatar
the timing cover will work
Old Jan 1, 2011 | 11:25 AM
Drac0nic's Avatar
depending on the intake I'd do the lifter valley before I did the valve cover. One less thing for it to drain through and chances are it wouldn't cause problems with your breather system/spew oil everywhere if something happened.
Old Jan 6, 2011 | 05:10 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
valve cover can work, or you can take that one to the fuel pump block off plate on the side of the block. Your turbos sit higher than or as high as mine do
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 13, 2015 08:28 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
