What can i put in my stock 84 z28 camaro to make it faster?
Old Jan 7, 2011 | 09:12 PM
moneyz1's Avatar
what do i have to put in the car or change to make my 305 as fast as it can get and were can i get the parts to do it?
Old Jan 7, 2011 | 10:51 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: What can i put in my stock 84 z28 camaro to make it faster?
what type of power adder are you interested in?
Old Jan 7, 2011 | 11:03 PM
moneyz1's Avatar
I was thinking of turbo charging it but I don't were to get a turbo charger that would fit in the car or were to buy it and if I did that would I have to change anthing else in my 30d for it to hold the added power?
Old Jan 7, 2011 | 11:09 PM
read this any you will see what it takes to turbo a car https://www.thirdgen.org/forums/powe...blow-thru.html
Old Jan 8, 2011 | 05:39 PM
hairysox33's Avatar
Flux Capacitors are on sale at Harbor Freight...
Old Jan 13, 2011 | 04:22 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Does anyone have a super coupon for them?
OP,
I think NOS would be better suited to your goals.
Old Jan 13, 2011 | 04:52 PM
P-ROC's Avatar
Car: 86 IROC-Z28
Engine: LB9
Money, lots of it. You did say "as fast as it can get", right?
Old Jan 14, 2011 | 01:35 PM
Ronny's Avatar
http://www.patmusiperformance.com/in...2_articleid=73
Old Jan 14, 2011 | 02:52 PM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
i agree p-roc MONEY !
mechanics are expencive , since you appear to have to car knowledge .
parts are expensive , no matter how car smart you are .
good luck !
Old Jan 18, 2011 | 11:09 AM
BadBowtie87's Avatar
Car: 1987 Chevy Camaro Z28
Engine: Flux Capacitor...
Transmission: fast, faster, and OH MY GOD!!!!
Axle/Gears: 4.11's
<-------------(look at engine spec) Hairy... shhhhhh.... only those secrets shared with the super special! But lemme tell ya, as soon as I hit 88mph....
All joking aside, enough duct tape and bailing wire, you can probably get a GE turbo fan to fit!
Ok... depending on what goal you set for yourself, is where you need to start. The goal is... "How much can I afford to do what I want to do". What is it that you want to accomplish? A street pounder? A weekend drag warrior? A road course warrior? These are the questions that have to be answered in order to put the best foot forward.
Old Jan 18, 2011 | 11:13 AM
moneyz1's Avatar
I wanna do the camaro proud I wanna be able to blow away a 5.0 mustang and all the lil tuners like the stis and the auties and even an m3 I want to prove american mussels wins everytime si what would u suggest
Old Jan 19, 2011 | 11:53 PM
hairysox33's Avatar
Is the 305 Throttle Body Injected? Or is it Carbureted? Either way, pull it out and live out the tried and true saying: "There's no replacement for displacement". Bigger the better!
You should be able to find cheap 350's locally on craig's. A Cam can do wonders to wake it up with bolt ons.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Fronzizzle
Aug 9, 2015 01:15 PM
