Nitrous
Old May 5, 2011 | 09:14 PM
84TransAm383's Avatar
Nitrous
New to nitrous and little afraid. I got a well built stroker but want a little more umph at the track. What could i expect from a 100 or 150 shot and what are the odds of blowing my motor also. thank for any input
Old May 6, 2011 | 12:58 AM
ZEXY's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: TPI 350
Transmission: Brog-warner 5 speed
Axle/Gears: Borg-Warner 9 bolt 3.45 posi
Re: Nitrous
my uncle dropped 1.5 second off his et with a 150 shot tho he only had a stockish 350 only had forged SRP pistions ran that way for 2 years only thing he did was keep checking his plugs (said it was the window to the cylinder) and made sure everything worked properly. only reason he stopped was because he went to a Twin turbo setup
Old May 6, 2011 | 11:58 AM
bduffey723's Avatar
Car: not a camaro anymore
Re: Nitrous
100-150 shot is fairly small so i wouldnt be worried at all. especially if you have it a little beefed up. just pay attention to your gauges and when u hear an unfamiliar noise, let off. or your motor will be done after 4 passes like mine. i was running a 500 shot my first time with no2 and man was i dumb.
Old May 10, 2011 | 04:03 PM
Ronny's Avatar
Re: Nitrous
N20 on > 2900 rpms. N20 on > 24 mph also be able to turn it off at redline as in a controller. spark retard as well and cooler plugs. again with a controller. my ecu supports all that. arm switch on ecu knows what to do.
Old May 10, 2011 | 08:47 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Nitrous
its all about air fuel ratio. a 100 shot is cool. a 150 shot is pushing it a tiny bit. anything over that is pushing an engine. air fuel ratio is the biggest deal. is the motor forged? was it set up for nitrous?
Old May 11, 2011 | 08:08 AM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
Re: Nitrous
i have also been thinking about this same thing.what if the motor is not forged or you dont know if it is
Old May 11, 2011 | 11:09 AM
bduffey723's Avatar
Re: Nitrous
i wouldnt do it. u still _can_ but things could get ugly.
Old May 16, 2011 | 10:28 PM
Re: Nitrous
yea its a fully built motor all forged and can handle it no problem
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
