engine combo for boost?
Old May 12, 2011 | 11:38 AM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
if anyone has some proven/idealistic engine combos for boost, feel free to share.
Old May 12, 2011 | 12:27 PM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: engine combo for boost?
um you might want to post alittle more info to get the help you want....4L, 6L, 8L? low boost, high boost? track car, street car? any info is better then what you posted lol
Old May 12, 2011 | 04:27 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
With boost you want to go fast...first and foremost. Then you want it reliable and cheap. Build it to those specs and you will have one nice setup.
Old May 12, 2011 | 06:23 PM
BrandonSB's Avatar
Engine: 30Slow
v8 350, 13psi, street car
Old May 13, 2011 | 12:56 PM
bduffey723's Avatar
Car: not a camaro anymore
just a basic answer..
a forged shortblock and a 76mm turbo
Old May 14, 2011 | 04:38 PM
Pocket's Avatar
Car: 91 Trans Am
Stock 5.3 with a blower cam. If the engine blows, get another one, they're that cheap
Old May 16, 2011 | 11:26 AM
BrandonSB's Avatar
Engine: 30Slow
hahaha thats a good point pocket, never thought about that. sometimes things just slip your mind.
itd be nice if it could last though.. hahahaha.
im gonna do some more reading on turbos.. lol.
Old May 26, 2011 | 12:01 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Strong parts, low compression, good heads, small-ish cam and you have a docile driving setup that will wake up on boost. Widen the ring gaps, strengthen the block. Basically all there is too it. Same as building any other motor for high power really. You want good machine work and quality parts that will handle the stresses. Ring gaps widen with boost compared to natural aspirated. Cams change alittle too. Thats a basic answer.
Getting it all the live is mostly in the tuning, but the better quality assembly/build, the better chance it will last. Machine work makes a big difference.
Old May 29, 2011 | 05:23 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Here is a supercharged 600+hp "pump gas" recipe you can build.
Runs on Sunoco 94 Ultra
350 block (4 bolt prefered)
"O decked" and bored +.030.
GM or scat cast or forged crank (either is strong enough)
GM or scat 5.7" rods.
Speed pro L2441F-30 -22cc Dished pistons.
(I believe Probe has a similar piston)
As said you want to be generous on the piston ring end gaps
on this supercharged motor. Bigger is better.
AFR 195 eliminator heads (75cc chamber) #1036
Cam: Comp cams CS XR 280R-10 street roller
K-12-771-8
Weiand 177cid blower.
2.33:1 pulley drive ratio. (3" blower and 7" crank pulley)
850-950cfm HP series holley carb.
1-5/8" 1-3/4" long tube headers. 2.5"+ dual exhaust.
28-30deg spark advance at WOT under max boost.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
toronto formula
Nov 10, 2015 06:17 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
