Procharger belt length.
Old Feb 22, 2012 | 09:19 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Hopefully you guys can help me out. My belt is now in belt heaven, it shredded so I can't get the belt length
I'm running the largest pulley(I assume), like 6#'s of boost. P1-SC unit.
Someone help me out with a belt size, it sucks driving with no blower lol
Old Feb 22, 2012 | 09:43 AM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: Procharger belt length.
use some string or masking tape in place of the belt, subtract a little bit to account for tensioner travel, and measure the length of tht - then order your new belt
fly89gta's Avatar
Car: 2018 Camaro SS
Yeah I could do that too, didn't think of that. I was hoping someone had a few numbers they could give me so I could order up a few belts and try them.
Old Feb 22, 2012 | 12:34 PM
TransAmGTA88's Avatar
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
String method is going to be your best bet.
Old Feb 22, 2012 | 12:40 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Ok, thanks guys.
Old Feb 22, 2012 | 12:44 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
P1SC w/8" 8-rib crank pulley setup...
Drive Pulley Diameter, ProCharger Part#, Belt Length...
4.25" - DB660I-8 - 66.0"
4.00" - DB653I-8 - 65.25"
3.70" - DB645I-8 - 64.50"
3.40" - DB645I-8 - 64.50"
Old Feb 22, 2012 | 12:51 PM
fly89gta's Avatar
Car: 2018 Camaro SS
That's what I was looking for, thanks man!
I assume the 4.25'' is the 6# pulley?
Old Feb 22, 2012 | 12:57 PM
Yes...
Old Feb 22, 2012 | 01:42 PM
fly89gta's Avatar
Car: 2018 Camaro SS
You rock.
Old Feb 22, 2012 | 01:52 PM
Twin_Turbo's Avatar
DO NOT!!!! go by the length printed on the bel, I have had this issue, a bunch of difference between the manufacturers. Check the number on the manuf site/catalog and check the actual length.
Old Feb 22, 2012 | 03:01 PM
fly89gta's Avatar
Car: 2018 Camaro SS
It least gives me an area to start at, I'll get a few belts around that length and start trying them.
Old Feb 25, 2012 | 10:56 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Hmmm that's with a 8" crank pulley, think most of these kits come with a 7.65" one, there are old post on sizes around but that will get you in the ballpark.
Old Oct 17, 2012 | 03:36 AM
dgon4948's Avatar
Car: 89 Trans Am GTA
you think i would be able to pull of a 61.5" belt on a 3.4" pully?
Old Dec 30, 2012 | 12:29 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
3.40 inch pulley here with the 64.5" belt.
With the tensioner (who designed that!?) all the way it still is a little loose..
-- Joe
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
