Intake Temps under full boost??
Old Mar 7, 2012 | 09:35 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Woundering what some of your guys intake temps are at when under full boost in the 1/4 mile or just when your under boost for a good 10-15 seconds. Im getting a 30-40 degree* temp rise when under 10psi of boost for 14 seconds...Is that somewhat normal?? My intercooler isnt the best. These numbers are on a 65* day...today. Im not having problems with spark knock or anything, but I just wanted to know what kind of rise you guys get under full boost.
Its 28x7x2 1/2" (tube in fin design). I was thinking of changing up the airdam so that it will guide the air into the IC better. Any ideas on that.
Old Mar 7, 2012 | 10:24 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Intake Temps under full boost??
meth injection ...
Old Mar 7, 2012 | 10:54 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I usually see a 5-10° IAT increase.
Old Mar 7, 2012 | 05:41 PM
fasteddi's Avatar
Car: 1991 Camaro RS
OK thanks for the reference, I need to re-route my intake air to the turbo, its just sucking in warm air and that raises the Intake temp by 10-15* from ambient right there, underhood temp are killing me.
See...this set up for getting cooler air really is bad isnt it???
Old Mar 7, 2012 | 09:48 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
the air filter location isn't ideal, but plenty of BIG power car's pull air from under the hood like that.
The fact that you have mild steel charge pipe is going to be more of an issue, it just will not dissipate heat like aluminum will. It will also heat soak much worse.
Old Mar 8, 2012 | 07:04 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Intake temps are steady at 10 degrees above ambient when driving arround yesterday in town and such. It was a little over 70 degrees outside.
I know its not the Ideal chargepipe though..
Old Mar 8, 2012 | 07:14 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
I also use steel intake tubing. But I have the air filter on the underside of the battery tray so it’s not pulling any warm air.
Old Mar 8, 2012 | 07:30 AM
Drac0nic's Avatar
If you're having issues with underhood temps then a blanket for the turbine may not be the worse thing to look into with that setup. A bit of sheet metal can help you isolate the air intake off from the under hood temps too.
fasteddi's Avatar
Car: 1991 Camaro RS
I though of running it into the pass side fender, looks like it would get alot of fresh air there.
Happend to have a picture to helps me get some ideas?
Old Mar 8, 2012 | 09:41 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
LT1Formula
20
Nov 14, 2015 12:02 AM
1992Vortec
Aug 31, 2015 08:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
