Vortech Supercharger
Old Mar 10, 2012 | 11:25 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
Has anyone installed one of these vortechsuperchargers before? What kind of power gains did you get?
https://www.yearone.com/Product/DisplayProduct/82221
Old Mar 11, 2012 | 08:24 AM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Vortech Supercharger
The kit averages 6-8 pounds of boost, but the power being made will of course vary depending on the engine that it is installed on. How much power is your engine making naturally aspirated, and I will tell you what you should be seeing at around 8-psi...
Old Mar 11, 2012 | 10:07 AM
yaj15's Avatar
Car: 1988 IROC-Z
I've got an all internally stock L98. My mods are minor bolt ons. I've got a BBK 52mm throttle body, ceramic coated 1 5/8'' hooker headers and y-pipe. 3'' high flow cat and 3'' flomaster cat back exhaust.
Old Mar 15, 2012 | 11:26 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Just a little FYI.. That supercharger system has been discontinued for a few years. Year one lists all sorts of goodies for our cars that never show up if you order them.
Old Mar 15, 2012 | 11:27 AM
yaj15's Avatar
Car: 1988 IROC-Z
That sucks. I was hoping that wasn't the case. The only other one I have seen is the one from pro-charger.
Old Mar 15, 2012 | 11:45 AM
That sucks. I was hoping that wasn't the case. The only other one I have seen is the one from pro-charger...
The TPI setups were discontinued, but they still make them for the SBC family. Not sure if it will clear a third gen hood, but it does in fact clear a second gen hood. You would just need to do your own charge piping to lead to the throttle body, then sell the carb enclosure...
http://www.vortechsuperchargers.com/product.php?p=138
Old Apr 17, 2012 | 11:27 PM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
You got a P/M
Old Apr 20, 2012 | 06:35 PM
hot00frb's Avatar
Although vortech discontinued the charger they are still available at one of their distribution sites.go here http://rmcrperformance.com/contact-us.html i was looking into them myself
toronto formula
Nov 10, 2015 06:17 AM
anesthes
Sep 30, 2015 07:48 AM
-=Z28=-
Sep 24, 2015 10:21 AM
anesthes
Aug 24, 2015 08:32 AM
PestilenceIV
Aug 20, 2015 03:32 PM
