rebuilding 350 not to sure on hp
Old Jul 18, 2012 | 06:28 AM
Justinb2288's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Formally 3.08/ Now 3.73 Posi
OK so I'm going from a 305 tbi boat anchor to a 350 block I got out of a 90 z71 truck. Comes stock with 200 HP. The cylinder walls have some surface rust but not bad. So I want to put a lunati voodoo can .489 lift edelbrock performer intake. I want to get around 300-350 HP. What else should I do.
Old Jul 19, 2012 | 11:55 AM
355sleeper's Avatar
Car: 1991 camaro rs
Engine: twin turbo 406
Transmission: th400 w/brake 4400 stall
Axle/Gears: 3.42s
Re: rebuilding 350 not to sure on hp
im using this cam on a 355 with 9.4 compression. the cam part number is 60103 if its the one you are thinking of. im using vortec heads and a jegs 331 intake(same thing as performer rpm) and a holley 650 carb. this set up is 375 to 400 hp. enough to run low to mid 12s. just something to look into. its a very cheap set up. top end kit from jegs is 850
Old Jul 21, 2012 | 12:44 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
You can run low to mid 12's with 375-400hp in a 3rd gen? That's a little optimistic but I would say very high 12's are possible. For 350hp? VORTEC HEADS and matching intake. Best bang for the buck. You can't go wrong. Camshaft in the range of 210-220 duration at .050 would be a great mild combo. Keep in mind with stock vortecs you may need to swap valve springs depending on cam.
Old Jul 21, 2012 | 12:48 PM
Car: 92 Camaro RS
Engine: 305 TBI
Yeah I believe as long as I stay under
500 lift I'm good
Old Jul 21, 2012 | 01:11 PM
355sleeper's Avatar
Car: 1991 camaro rs
Axle/Gears: 3.42s
Yes you can get mid to low 12s in a 3300lb car with 375 to 400 hp with optimal gearing, converter, and tire
Old Jul 21, 2012 | 09:32 PM
Car: 92 Camaro RS
Engine: 305 TBI
Yeah I got a 5 speed and getting 4.10 gears
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
Magman
Sep 13, 2015 08:43 AM
fbirdroller
Sep 2, 2015 10:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Eric-86sc
Aug 24, 2015 09:01 PM
