anyone running an air 2 water intercooler
with the current rebuild of my twin turbo iroc ive been thinking about going with an air 2 water setup.
looking for some feedback on hese though for street use, i know for drag apps these etups are the cats meow.
this is what i was looking at getting
an almost 6 gallon water/ice tank
http://www.ebay.com/itm/Water-to-air...7b4074&vxp=mtr
and maybe this intercooler that i will cut up and modify as needed
http://www.ebay.com/itm/Liquid-Water...f7af0c&vxp=mtr
im thinking cut it in half and stack the cores side by side so its 2x as thick and only half as wide si it fits up in the dash or on the passenger side floorboard
how much street use can u get out of one of these systems before they heatsoak
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: anyone running an air 2 water intercooler
i've seen guys run a cooler for the water, similar to a trans cooler, to keep the water temps in check
my biggest problem is if i stay with an a2a setup my 32x16x4 core isnt enough for the new engine id more then likley need 2 a2a cores that size
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Isn't enough? How much boost and HP you planning on making? Thats a huge a2a. Mine is alittle smaller than yours and rated to over 1000RWHP. Its for a Supra
I have one, meziere water pump temp switch controlled, small reservoir and a stack oil cooler I'm using to cool the water. Once the pump kicks in charge temps plummit.
thanks
Heat soak the tank? The pump runs on boost and off a switch on the dash so the water is cooled, no heat soak
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
I did a PT1000 intercooler in the firewall. There is room for a bigger one but you will start reducing leg room for passengers.
My heat exchanger is a 2.5" thick 14"x24" griffon radiator. Mounted under the hood latch area. It has a fan on it also. Lots of room in between it and the engine radiator/trans cooler. My radiator air deflector still does its job and shoots air up to the rad. I use an aerospace remote mount pump and a mix of 3/4" and 1" hoses and cheap plastic fittings to keep it cheap/light. My heat exchanger is overkill and,Im hoping it works so well I won't need a big tank of water anywhere in the car. This dtuff adds enough weight as it is. Im hoping this cooler setup and a small shot of meth will give me 10psi with NO increase in air temps. Hoping... No data yet.
Transmission: 4L65E
Twin_Turbo's setup is hilarious. So much work to cool the air down but the air inlet is right above the header. Hottest pipes in the engine bay.
Your reply is hilaious in that you make assumptions based on ignorance and possibly hearsay. Certainly not hands on experience.. I am meticulous in everything and actually have a charge temp gauge on it. I fabbed a remote inlet setup and did testing. The difference in temps at the tb inlet between this and remote are negligibly small. So why would I add more clutter to it if it serves no purpose? Headers are wrapped, they don't heat up the engine bay that much.
Figures...no comment.
Heres another one of my stupid hot intake SC setups...it's gonna suck! what a waste of efort
or this one... sucks too!
so much fail by 1 person...hilarious!!
Car: 1989 Formula T-Top
Engine: 350 TPI, twin turbo
Twin if you would stop being so hilarious you would slow down! More hilarity!
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 92 Formula 350
Im running an air to water setup on my daily driver turbo jeep. I have a decent size heat exchanger up front (modyfied a/c evaporator core lol). I have the i/c pump on all the time with a gallon tank. In the summer it will get heat soaked in stop in go traffic then cool off if im driving higher speeds for awhile. In the winter, its ice cold all time. I wish i had the room to do an air to air setup tho. Im not a fan of street driven air to water setups, just didnt have the room to fab an air to air. Yes, thats the washer fluid tank. haha. I just circulate washer fluid thru the i/c. Saved me from finding a seperate resevoir and trying to mount it. I just keep a gallon of washer fluid in the jeep so i can keep it topped off.
eightsixseven
Dec 16, 2024 01:50 PM
Terrell351
Jun 13, 2021 01:13 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
1500, air, automobile, car, cool, cooler, exchanger, heat, hp, intercooler, passenger, pictures, side, transmission, water
