Chronicles of a 9 Second 305 Trans Am...
Old Nov 12, 2014 | 10:11 AM
  #701
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Chronicles of a 9 Second 305 Trans Am...
That's the problem though Will, and Justin essentially nailed it. With the current setup, and without a transbrake, I can't build boost off the line. However, with a much higher stall I will be able to at least foot brake to a better sixty foot with the current setup and maybe build a little boost and bring that ET down substantially. Trap speed won't change though until I add more power by upping the boost pressure. At 126-mph the GTA is a solid and consistent ten second car at 15-psi. Once I upload new features into the EBL-P4 later today I will start experimenting with 20+psi again, as I only had it up there a few times for tuning purposes, but that should catapult me into single digit ET land. Actually looking for a plain Jane no vent firebird hood (preferably Black of course), so if anybody wants to trade straight up, let me know...
Old Nov 12, 2014 | 10:14 AM
  #702
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You log your iat temps at end of pass?
What intercooler you running again?
Old Nov 12, 2014 | 10:27 AM
  #703
IAT's a tad over ambient at 65 degrees before making the pass, goes no higher than 72 degrees during. Alky would have brought it down tremendously, but when running in cool weather it doesn't really matter at such low boost pressure. Coolant temps stood at 180 degrees, engine oil temps stood at 190 degrees didn't budge, don't have a transmission temperature gauge just yet but that is coming. Intercooler is an ebay 4" core, 3" in and out universal front mount. Gotta double check but I think it might be the same brand as the T72 turbo and 44mm wastegate I am running...
Edit: Yes, intercooler is a Godspeed unit just like the turbo and wastegate...
Old Nov 12, 2014 | 11:42 AM
  #704
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats not bad at all! Mine rise like hell! I need a intercooler upgrade. After burnout and on tbrake i think i am in the 80-90 deg range start and see 170 on a 25 psi pull. In cold ambient... Not good
I saw 90 to 123 deg on 12 psi 2 yrs ago on same setup
Old Nov 12, 2014 | 11:56 AM
  #705
project89's Avatar
i have the same fmic as street does ,works great but im pulling it off the car in favor of an a2w setup so if ya interested in it let me know
Old Nov 12, 2014 | 12:12 PM
  #706
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If i dont go bell core i will just buy another identical core as my treadstone and weld them on.
I do need one for my 305 build tho
Old Nov 12, 2014 | 01:47 PM
  #707
zz17iroc's Avatar
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Congrats man! The 305 is getting it done. Can't wait to see more results when you add more boost and better convertor.
Old Nov 13, 2014 | 02:54 PM
  #708
That had to be the funniest post I ever read in my life, nine year member with a whopping 4 posts who goes out of it's, yes it's way to talk smack so everyone in the thread can read lol. PM me and we'll set something up since your so close. No PM underlines your full of crap. PM me.....
Old Nov 13, 2014 | 07:11 PM
  #709
Z28FAST1's Avatar
Was a bit skeptical with this thread but that trap speed shows it flying. I'm guessing the last tenths for a 9 second slip will be the toughest. Hopefully the engine holds
Old Nov 14, 2014 | 07:16 AM
  #710
Engine more than likely is going to blowup if I keep pushing it, and I am just being realistic because it's all cast. Plugs were fouled the last time I pulled them because of the tuning, but didn't see any knock indication on them. Snowed over here last night and surprised the whole damn township, so I am unsure of how the weather is going to be this Sunday. Almost traded the hood last night for something else, but a buddy convinced me to stick with it and get my hands on that ebay Holley Stealth Ram. Didn't realize how damn inexpensive it was even with the fuel rail setup. Good job Dave for bringing that deal to the forum's attention...
Old Nov 14, 2014 | 07:21 AM
  #711
Here are the details, Joe already broke the pricing down for everybody...;
https://www.thirdgen.org/forums/alte...ml#post5837248
Old Nov 14, 2014 | 07:32 AM
  #712
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I may do that chinese intake but like the look of TPI and trying to keep car as original as possible
Old Nov 14, 2014 | 07:51 AM
  #713
I gotta be honest, siamesing the stock Tuned Port setup did help tremendously on the street with RPM, but the stock runners really are holding the engine back. I would definitely get a bigger throttle body and larger aftermarket runners when sticking with the TPI over the HSR. I really like the TPI look too, the kids that work over at the wawa by my house always ask me to pop the hood when I am there, and are always complimenting the "spider" look that it has...
Old Nov 14, 2014 | 08:03 AM
  #714
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I want to find a set of slp runners but dont wanna pay an arm n leg for them
I would be happy with mid high 300's whp. SHould get my light 91 into bottom 12's or high 11's, which will surpass my old daily driver ls1 ta
Old Nov 14, 2014 | 11:46 AM
  #715
project89's Avatar
its even cheaper then when i bought my 3 now.
when i bought mine they were 285 each new shipped, now they are 200 each shipped new its a helluva deal
Old Nov 14, 2014 | 02:33 PM
  #716
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
Originally Posted by TenthYrTA
im just going to say ... stop
you seem to think post count makes you right ...dream on
oh and remove my ph number from your contacts
^^^What's with the troll?
Old Nov 14, 2014 | 03:20 PM
  #717
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
.streetlethal knows me and knows im no troll , dave (project 89 nows me too ..i dont know you from adam
i played with pontiacs before most of you guys were born , just never really posted here and had more cars than you could imagine mostly second gens but i stil haev a couple third gen pacecars
the screen name is mine and what i used since the internet started
then i went to buick turbos back in 99 and have been playing with them if you want you can find me as pacecarta on the turbobuick boards
Nice back ground but that still doesnt change the fact that you are 'trollin' the thread as you havent posted in the thread before and now are making claims that this result isnt real... Now if there is a reason for it then spill the beans. Is it your slip?
Old Nov 14, 2014 | 03:31 PM
  #718
Yes I do know him, very well I might add. The reason why I responded that way is because I didn't even know who he was at first, the user ID was not familiar. I thought it was an LSX thumper from over in the theoretical section at first. Telling me to lose your number was really effed up man, why didn't you answer my call?
Old Nov 14, 2014 | 03:47 PM
  #719
Originally Posted by Drac0nic
I believe that is indeed what he is implying. Timeslips with an "s" implies that there are more than a few. Post one of the same car # on the same day at the same strip, or write today's date on that slip and post a pic up if what you're implying is true.........Afterall, you can't trust everything you see on the internet, right?
Listen, don't turn my thread into this garbage, perhaps start your own thread for that...
Old Nov 14, 2014 | 05:19 PM
  #720
Are you serious with that ridiculous statement texas lol? I am still waiting for you to post "something", ANYTHING, but you and Draconic have posted nothing, you just feed off of everybody else's builds. I already said I didn't want to post timeslips, I would rather post a video, I have said that over and over. I know what my car runs, do you yours lol? Any videos? Anything to offer? Tell you what, I will post the video of my run when you do...
Now again, keep your rants to yourself, or start another thread of your own.
Old Nov 14, 2014 | 05:31 PM
  #721
Silence is golden isn't it Texas lol. You, Draconic and Junk, all of you profess to know your stuff, yet I haven't seen anything for an elusive boosted $8D code for one, turbo headers that still aren't done for another, and last but not least a BLOWN UP engine for the third. Yup, and I'm the one who, who's engine is still going strong, who's headers are done, and who's boost code works, doesn't seem to know what he is doing lmao. Nobody asked you to follow this thread texas, and I certainly am not doing this to entertain you, so don't feel as if I owe you anything. I can appreciate the attention though...
Old Nov 14, 2014 | 06:40 PM
  #722
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Somethings take time i can understand that. My second combo was completed to run 8's over 3 years ago! It had all kinds of issues and ran 10.5 haha. Took me 3 years to get it all sorted out and finally to run what i claimed it would.
I'll give street the benefit of the doubt cuz i have had my troubles with builds. I just wanna see how this 305 runs because i am building one
Old Nov 14, 2014 | 08:01 PM
  #723
Justin, I already told Joe in a private message that I am done with this thread after I post the final 1/4 mile video, and even then I don't know why I'm even going to bother taking the time to post it with the some of the idiots that post in this forum. Almost 200 bin files later flashed into this engine and all of them tuned based on performance via 60', 0-60, 1/8th and 1/4 data through the EBL's Data logging Analysis screen all being done on the street and on the highway, from a dead stop and a roll, I have known what this car would run a very long time ago with half of the bins being tuned to 8-psi, and the other half being tuned to 15-psi, the engine took a freaking beating. I've shown the fuel consumption at just 7-psi from the WUD directly, and horsepower was over 400, but that was a waste of time because most of the members here don't even know what they are looking at. I will post the final 1/4 mile video for the sake of this thread, and for the members who want to see the GTA's outcome, and no it won't be "cgi" (rolleyes) but until then, just leave the thread alone, I am not posting anything else being done to this project because it literally is a waste of my time at this point, so let's see what you guys can do with your turbo power house builds in the interim...
Old Nov 14, 2014 | 08:40 PM
  #724
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
If you guys want to post bullshit and act like a bunch of babies go post in the street racing forum where the idiots belong.
This forum is for posting tech relating to forced induction combinations, not for stirring up nonsense because you don't like how somebody spent their money.
-- Joe
Old Nov 15, 2014 | 08:45 AM
  #725
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
heavily considering buying on of these and going fuelie on the l69 over the winter. it probably needs rings though dat blow by
Orr89RocZ
Apr 25, 2016 08:28 AM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
