and so it starts
Old Jan 28, 2015 | 10:24 AM
  #601
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: and so it starts
Originally Posted by project89
Running that PCB and components open to environment underhood looks risky.
Old Jan 28, 2015 | 10:28 AM
  #602
junkcltr's Avatar
Engine: 3xx ci tubo
Originally Posted by 34blazer
Well I think that's what the relay does, solid state PWM for accurate control.
Solid state is a silicon device. Relay is a mechanical device. When you PWM that relay it bounces around when you turn it on/off. It arcs the contacts if you don't have a clamp/freewheel diode install. A relay is very inaccurate. Accurate control of a motor at sub 20hz control is not needed and that is why the relay works. The relay has a higher failure rate than a solid state (MOSFET, BJT, etc) device.
Old Jan 28, 2015 | 11:04 AM
  #603
t-top89's Avatar
Exhaust gas temperatures and cylinder pressures will be changed when switching between the two. I dont know if he is racing this car and getting the last drop of HP or just playing.
Old Jan 28, 2015 | 02:15 PM
  #604
RBob's Avatar
Car: check
Engine: check
Transmission: check
The nomenclature that Chrysler uses is 'fan relay,' that is what they call it. In which I don't really care, why, because I know that it is a solid state high side switch.
Chrysler uses it to regulate the engine's electric cooling fan speed via PWM from the ECM/PCM. Works great to do the same for the alky pump.
RBob.
Old Jan 28, 2015 | 11:39 PM
  #605
34blazer's Avatar
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
RBob.
Again I fail at knowledge and engrish. Thanks for the clarification
Old Jan 29, 2015 | 12:04 AM
  #606
project89's Avatar
it wont matter , i dont use the alky as a power adder , only as an extra cooling/saftey net
tune gets set with no alky , then ill setup the alky so it cools the charge further without messing with my afrs . this is my street car so it wont be running on the edge
Old Jan 29, 2015 | 12:07 AM
  #607
project89's Avatar
been thinking about it , manufacture says its ok , its just a relay board for the arc 4000 , but im going to move it into the car
speaking of the car , lets just say its losing quite a bit of the front end over the next few days
Old Jan 30, 2015 | 02:46 AM
  #608
project89's Avatar
what do u guys thing of twin 76's ptrim turbins with .81 housings?
Old Jan 30, 2015 | 09:01 AM
  #609
junkcltr's Avatar
Engine: 3xx ci tubo
My guess is that with a comp that large and smaller turbine it is going to spool soon enough to cause compressor surge. I am interested to see how it works out. If it ends up with surge at low boost then put in a cbv activated in the surge area. I just had to do this on an install to clean up surge at 0-3 PSI.
Is there conformal coating (goo) or clear coating stuff on the board?
Old Jan 30, 2015 | 09:03 AM
  #610
junkcltr's Avatar
Engine: 3xx ci tubo
RBob.
Ah, didn't see where it said a Chrysler fan relay. I was thinking classic mechanical GM fan relay.
Old Jan 30, 2015 | 10:21 AM
  #611
project89's Avatar
yeah im kind of torn atm , i shoudnt have bought the t76 i did , it was an impulse purchase and i grabbed one with the wrong turbine housing
this is the reasoning betwen buying an 88 for the track
so it got me thinking if i could just buy another matching t76 and make it work , or maybe sell off the 76 and just buy an s475 or something
if i wanted to do twins again twin 66-70mm is prolly what i should have
yeah the board has coating on it , but im moving the battery to the trunk so ill be moving the relay panel as well
Old Jan 30, 2015 | 10:52 AM
  #612
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Whos T76 is it and what are the specs ?
The kid I sold my other turbo stuff to might be interested.
-- Joe
Old Jan 30, 2015 | 10:55 AM
  #613
project89's Avatar
-- Joe
on3/ebay/china true 76mm compressor , ptrim turbine with an .81 housing ,3" band vband outlet
Old Jan 30, 2015 | 12:57 PM
  #614
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
80mm GT45 with a 1.15 ar will do you nicely
Old Jan 31, 2015 | 02:12 PM
  #615
project89's Avatar
yeah but at that point im better of spending the extra few bucks on the s475, those 80mm gt45's are like 600+ each iirc
Old Feb 2, 2015 | 03:00 AM
  #616
project89's Avatar
looks like im going with an s475 or an s480
thinking about a s475 with the billet wheel option and race cover
Old Feb 2, 2015 | 04:35 AM
  #617
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
It's an ON3 T76? .96 or 1.10 exhaust housing ?
Sounds like the same one I have.
Compressor Wheel 76mm
.80 a/r
4' Inlet and 2.5' Compressor Outlet
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
Exhaust Housing T-4 Flange:
.96 ar Exhaust Housing
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 65mm
-- Joe
Old Feb 2, 2015 | 05:04 AM
  #618
project89's Avatar
.80 a/r
Inducer- 76.71mm
Exducer- 102.36mm
Exhaust Side:
3.0" Vband outlet
Inducer- 74.5mm
Exducer- 65mm
-- Joe
same turbo u have except instead of the .96 turbine its got an .81
Old Feb 2, 2015 | 05:15 AM
  #619
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Ohhh the exhaust side is .81.. So it would be good for TPI or something that needs to spool quick but not rev too high.
How much are you selling it for?
-- Joe
Old Feb 2, 2015 | 05:39 AM
  #620
project89's Avatar
-- Joe
yeah
same price i paid for it 315$ its only been taken out of the box hasnt even been mounted on a header yet
i also have the t4 flange and 3 inch vband and clamp for it ill sell as well
Old Feb 2, 2015 | 08:09 AM
  #621
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Way to big unless you want 1200 whp
Old Feb 2, 2015 | 08:58 AM
  #622
project89's Avatar
umm yeah not on this shortblock lol , 800whp will be just fine
Old Feb 2, 2015 | 09:24 AM
  #623
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah just saying i dont think a small cube non race motor would like those turbos. They wouldnt spool well. The .81's would def help, do not need bigger. I run the mp p trim .96's and dont see full boost til 4200 but they start to make noise around 3600-3800. Just come up to 20 psi abit slower. Hit harddd by 4500 as converter opens all the way out.
My friends 6.0 notch runs the twin on3 76's on .96's as well. E85 and aggressive tune it will spool them but also takes alittle while. Hes been over 1050 whp with them
Not sure why you sold the other small turbos. A single 475 with the 83 mm turbine would work well, or even 7675 turbonetics or magnum 7675
Old Feb 2, 2015 | 09:40 AM
  #624
project89's Avatar
the gt3076's were to small on the turbines they moved a ton of friggen air at idle , been thinking about the 7875 for 399 from vsracing but i may as well just grab the s475 and know it will hit 1000 crank
im sure i wont have trouble spooling it witht he 3800 stall and transbrake and if i do i still have that nx direct port kit i can put to use plumbing it on the hsr presents its own issues though , id prolyl have to make spacers to go under the plenum
Old Feb 2, 2015 | 10:17 AM
  #625
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You wont have problem spoolin a single 76 with one of those smaller 75-83 mm turbines with right housing
Old Feb 2, 2015 | 02:01 PM
  #626
project89's Avatar
oh i meant the s475 with the t6 1.32 turbine
Old Feb 2, 2015 | 03:57 PM
  #627
junkcltr's Avatar
Engine: 3xx ci tubo
The S475 is a good unit. I would pick the 1.32 housing. With lots of digging you can find a JDere unit that has the "race cover" and have an HP-series wheel installed.
I don't know why china puts small turbines on big compressors. But then again, they undersize the comp housing A/R for a given wheel.
Check out the Garrett turbine flow maps to figure out overall flow. You typically want 45-50% turbine flow of the compressor flow for best power.
Old Feb 2, 2015 | 04:42 PM
  #628
project89's Avatar
right now its a tossup between the chine 78/75 the china 80/83 or the s475
Old Feb 2, 2015 | 06:08 PM
  #629
86trbota's Avatar
Car: 86 trans am
Engine: 383 dart 215 billet 84mm s400
Transmission: th400
Axle/Gears: 3.08
might as well get the s475. its a quality turbo, will make great power and you can get them upgraded with 80+mm billet wheels for under $500. a box stock s475 will give a stock block a workout.
Old Feb 2, 2015 | 06:32 PM
  #630
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah but that t6 frame is huge lol
Old Feb 2, 2015 | 09:29 PM
  #631
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
lol. yes they are huge, that is the only downfall in my opinion.
Old Feb 3, 2015 | 02:51 AM
  #632
project89's Avatar
thats why i have a sawzall and plasma cutter and a welder................................ to make room for that big bitch lmfao
anyways over the next few days ill make my choice , cars on hold right now for atleast another week as the shop is packed full with farm equip its so bad u can barley walk threw the shop
any one of those 3 turbos should do 800whp , but its prolly going to be the s475 that i get so i dont have to upgade yet again down the road .
if anyone wants that t76 i got let me know im prolly going to put it up on ebay in the next week
Old Feb 3, 2015 | 12:12 PM
  #633
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
i cut all that crap out and have a ton of room to work and on everything now.
Old Feb 3, 2015 | 12:15 PM
  #634
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
When you cut that rad support and headlight bucket areas out does it weaken the fenders or front end at all? I dont think it would but i'm about to cut mine out for weight
Old Feb 3, 2015 | 01:19 PM
  #635
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
i didnt notice anything at all. the metal that is in their is very thin and in my opinion has no structural support. i am redoing my rad mount and im going to tie in the front frame rails to add a little support.
Old Feb 3, 2015 | 01:22 PM
  #636
86trbota's Avatar
Car: 86 trans am
Transmission: th400
Axle/Gears: 3.08
i am going to build something similar to this. i got these pics from jakesperformamcefab.com those guys are very talented fabricators.
Old Feb 3, 2015 | 02:06 PM
  #637
project89's Avatar
the reason i havent been working on the car lately
lil hard to fit it in the shop right now
since it was nice out today i worked on it a bit outside, made room for installing an s475
Old Feb 3, 2015 | 07:02 PM
  #638
project89's Avatar
got a manual steering box comming , thinking about ordering up a motorplate while im at it
Old Feb 4, 2015 | 04:42 AM
  #639
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You are dangerously crossing into strip only territory.
9 seconds is wicked cool if it's got power steering, motor mounts, full interior, and it can make a 300 mile trip without over heating.
You start turning it into a track only car and you've lost your coolness.
-- Joe
Old Feb 4, 2015 | 05:39 AM
  #640
project89's Avatar
-- Joe
i just prefer the manual steering , the motor plate was just a thought prolly wont do it. as far as whats a street car and whats strip only, as long as u can legally tag and insure it its a street car
case in point 9 second pump gas car
front /mid plates manual everything tag registered and street driven more then its raced
Old Feb 4, 2015 | 07:17 AM
  #641
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The state I live in you can tag and insure just about anything with a motor.
If the vehicle is 20 years old, emissions equipment can be removed. (yes, removed!) you an alter pretty much everything. The only thing they don't want is fuel cell's in the trunk for some odd reason.
-- Joe
Old Feb 4, 2015 | 07:40 AM
  #642
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Joe's got a point Dave. Nothing more cooler than a fast vehicle with full interior driven on the street, legally. Case in point, Sal's old 6 second twin turbo Dodge Viper, full weight, still has IRS too. This is the greatest and fastest street car on the planet, and it weighs more than your Iroc, running a drag radial too, 6 second car, so don't get too carried away bro with weight reduction and frame modification...
Old Feb 4, 2015 | 08:29 AM
  #643
DIGGLER's Avatar
Im putting the power steering back on mine. Lol
Old Feb 4, 2015 | 09:57 AM
  #644
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Gives me hope that 7's arent to far from reach in a full body street ride lol
Old Feb 4, 2015 | 11:46 AM
  #645
project89's Avatar
mines comming out to keep the wife from driving it , though with the skinnys on the front it prolly wont stop her.
rob its not about wiegth reduction and all that its about getting that big bitch of an s475 to fit lmao. reason i thought about the motor plate was so i could do single 5 inch off the turbine into dual 3 inch down past the engine , really dont want to dump a 5 inch downpipe infront of the front tires
Old Feb 4, 2015 | 12:04 PM
  #646
Shouldn't be a problem Dave. I stepped up to an 88mm turbo and the hood still closes, just had to cut the downpipe a little because it was now hitting the firewall. I thought about cutting the rad support out too back when I started, but after seeing how fast some V6 guys are running with regular under the oil pan meeting on the passenger side setups, figured why give myself that extra work. Valve springs are too weak, and the tensioner pulley is chirping like a ten foot sparrow, other than that, very easy to work on, just waiting on outside temps to at least reach freezing to do it, which is sarcasm because its been like 0 degrees lately...
Old Feb 5, 2015 | 10:04 AM
  #647
junkcltr's Avatar
Engine: 3xx ci tubo
S475 can be put over in the battery tray area too.
It will be interesting to see how much ET it gains. I looked at your thread but the smaller turbo timeslips have disappeared. What was the ET with the old turbo? Gonna do chronicles of 8 sec thread with the 88mm unit?
Old Feb 5, 2015 | 11:11 AM
  #648
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How do you support the turbo? Make a brace to the frame, and then a flex pipe to the hot side ?
-- Joe
Old Feb 5, 2015 | 11:36 AM
  #649
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
-- Joe
Basically what i did for my twins. May not need bracing but i felt better with it. Braced to fender
Old Feb 5, 2015 | 11:45 AM
  #650
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Too much leverage on aluminum heads IMO.. I'd brace it.
-- Joe
