and so it starts
Re: and so it starts
new turbo arrived and of course gota take pics with a 2L bottle of soda for size
now that i have one , i think it needs a twin
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
I used to run the .81 exh housing.....I felt it was too small and at that time souldve bought the .96 housing. I ended up selling that and going with the cs racing gt 45 model with the 1.15 housing.
single t76 as a test , if i like the single setup more then the twins ill get an t88 or a bw s475 with the upgraded wheel,or possibly the gt45 witht he 80/88 mm wheel . or ill just go back to twins and put the 66's on it. twin t76s would be a lil much for my combo
yeah i was torn on the .81 housing but i can always pick up a different housing pretty cheap if need be, this is just a test run for me anyway
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I have a .96 a/r housing on my T76. I think it's a little small for my build, when you consider the amount of air my motor uses n/a it kinda puts me off the efficiency island.
Oh well. It's paid for.
-- Joe
-- Joe
new passenger side header just have to get the collector stright and weld it
not the best but for making them soley out of an old set of longtubes they cam eout just fine
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
yeah thats the other set i was thinking of selling and still may , so i can build yet another set so i can push the collectors back 2 inches
i have a single tube to finish on the driverside to clear the steering shaft ill get that done today, and should have time to start building the xover for the 76
the goal today is to complete the hotside minus the downpipe as my downpipe flange got back ordered on me
might be a lil rough though as i had a wheel bearing go out on my 4wd explorer yesterday so i need to get that in the shop and apart and see how much damage there is on that and get that fixed as well
the dog isnt mine or my friends was one sof his cusotmers dogs dont know his name
also i fixed what i thought was an ignition issue with ms yesterday, aparently i had the tpsdot threshhold to low and it was triggering ae , so pulse wisths were going from 1.2ms at idle to 4.5 for a split second and when i was cruising around at 2-3k rpm and it would trigger ae pulsewidths would more then dbl causing a very quick way rich condition.
i actually shot a video of it in the shop while it was fixing itill have to post that later , i do belive i still have a lil bit of ignition breakup when i post the video i think u will be able to hear it when i hold the engine between 2-3k rpm steady it sounds like a real slight breakup, but i also need to pull the plugs and make sure they arent fuel fouled or anything
also i gota send ya pm here later today should have the money for that transbrake/vb bellhousing etc in 3-4 more days
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Again, I'm not sure how to do the merge. I'm using the 2" weld els. Not sure if I should just rob a y-pipe from the shop. I think I have one from a 4th gen 3800.
I just went to 60lbs siemens injectors and and a new FPR, so hopefully once the new hotside is done I'll get fuel dialed in properly.
-- Joe
I've got all the parts to do mine now, I'm just a little uneasy about the merge. I built a jig last week to hold the T4 flange where I want it. First thing I think I'm going to do is weld up a bracket for the flange so it's not held just by the tubing.
Interesting. I wouldn't have thought to check that. Your using ms2extra, right?
When I pulled my header off, and checked a few plugs they had BLACK BLACK soot. I mean it looked like chimney sweeper black. Which is odd, cuz my wideband always reported between 13-14:1, which I'm assuming means I had some exhaust leaks pulling in fresh air..
Sounds good. Do you want the case ? If so I'll mount the VB on it and get a box at staples.
-- Joe
-- Joe
running ms1 extra right now , way back when i first installed the ms i thought the ms2 cpu went bad cause of fueling issues i was having so i bought and swapped in an ms1 cpu, turns out the base settings for peak and hold injectors are not correct for precision injectors and thats all it was, one of these days ill switch it back to ms2/extra if i dont just spring for the ms3 cpu and ms3x board
when u figure out placement ill show u a few tricks to building a good flowing merge
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
That TH350 case has some other mods too, I think forced oiling and some of the cavities are bored out with a dremel or something, I'm guessing for fluid release. I dunno.
Just make sure you measure the case to bell clearance with your pump. If for some reason your pump is a hair more shallow you don't want the bell housing being held up on the case or it will leak. Your supposed to torque it down and run a feeler guage around the whole thing.
-- Joe
Once I'm done doing the family Christmas tour all over New England this week I'll get back in the shop and post pix to my thread.
-- Joe
-- Joe
the only thing im going to say is FIRE FIRE FIRE
will investigate in the morning
not sure if it was actually a fire or what.
Now that im watching the video, we looked over the car once we pushed it into the shop and couldnt find anything burnt , but there was smoke pouring out from the hood and into the car
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
firefirefire - YouTube
-- Joe
Car: 89 Camaro RS running MS2X
Engine: .48/.60AR T3/T4 2.8L V6
Transmission: Rebuilt 700R4 2500 stall
Axle/Gears: Next to break...
Video Link: https://www.youtube.com/watch?v=MgXE1dm0V2c
Sure looked like oil on the headers, but hard to tell.
the smoke was aparently either fuel vapor from the hot header being filled with gasoline or something not really sure . im on lunch break now , but heading back to work on the car in about an hour im going to pull the harness and sheck for burns or shorts
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
wasnt oil , the entire passenger side bank of injectors is stuck open , either the ground wire shorted somewere or i have other issues .
-- Joe
joe im going to need ur help figuring this one out if i rember right ur an electronics guy
heres what i have found , if the ms is powered off and i kill the 12v power to the relays and prime the fuel system fuel presure holds with a very slow bleed down , 30 mins form 45 psi to 0 , my cheap regulator bleeds down
#2 prime the fuel system and turn both the ms and injector 12V + on at the same time presure holds and bleeds down the same as #1
heres were it gets funky
#3 prime fuel system and leave ms powered off , but flip on power to the injectors and instand presure bleed form 45 ps to 0
this tells me the ms that either the ms leaves the injector circut grounded when power is off or that something is wrong and its back feeding ground threw the injector drivers
my ms is powered out of the fuse panel on an unused circut that is hot in run and crank . for saftey i have both my injector and coil power off a 40amp relay on my arc-4000 switch panel
ideas suggestions? btw im using ms1 v3.0 with the latest ms/extra code
in other news i started mocking up the new headers today , but with it being 15* out i didnt get much done
im going to shorten up the passenger side by about 1.5 inches so its just behind the alt, and have to modify one primary for 4.5 inch downpipe clearance.The driver side is right were i want it.
im also getting the itch to exchange this t76 for one with a .61 housing and then buy a matching t76 with the .61 housing and put twins on it and make use of the direct port nitrous system i have
oh yeah and this is a must lol i really need to get back to work on my turbo dirtbike project
injectors should be fused switched power on during crank and run. ms is grounding the injectors when it is in the off position. when you flip power on to the injectors you are simply turning them on 100% as long as the ms is off.
i dont believe the ms should be grounding those circuits when off, will need to dbl check that. its also no big deal to move the ms power to my switch panel and put it on the same relay as the injectors
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
From the manual: "You must use a "main relay' that supplies both the injectors and your MegaSquirt® controller, as shown in the external wiring diagram above. When your MegaSquirt® controller shuts down, the injector driver states are 'indeterminate' and might allow current to flow through the injectors. Thus the injectors might stay open and flood the engine if the MegaSquirt® controller isn't powered but the injectors are powered."
So yes, it's quite common to be grounded upon power off.
In stock form, the injectors would be powered through a circuit that is only hot during CRANK and RUN. Just turn the relay on when under those conditions and you should be good to go.
I was supposed to pick up a load of hay today and then spend the day in the shop, but it's raining. So I guess I'll spend the day in the shop.
I have not been on a dirt bike since my early twenties. I have a bagger, but it's not so good in the dirt haha
-- Joe
My MS is powered through a switch, but its also switched power so either the switch, ignition being turned off, or both shuts the MS down. My injectors are wired as they originally were stock, so they still work as stock, ecm switches the ground. The extra switch is a theft deterrent.
Therefore I shut the key off, both MS and injectors shut down.
So even if the injectors are grounded, key off provides no power to the injectors.
joe the coal fired furnace was acting up made for a really cold day
anyways looks like i got some rewiring to do , funny thing is it just started doing this
hacked up the headers i built again and turned them into a pair of theese , they were originally a set of long tubes that i cut up and hacked back together to make turbo headers, then i hacked them up again to make this design.
these will be temp till my new stainless flanges and tubing get here so i can weld up a nice pretty set
and no the flange isnt bow'ed the camera i have has a 135* lens so the pictures get that fishbowl effect
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How close to the hood is that going to be ?
I've seen some stainless sets on ebay that are basically run the same way. I'm still on the fence about running a crossover in the front between the fans and engine. Not a lot of room for such a hot pipe.
-- Joe
-- Joe
not even close collector is at valve cover hieght , ill grab some pics on the car today , though i goofed on the driver side the header ust clears the prop valve so i need to refit it and move the tubes 1/2 inch closer to the head
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Last night I stumbled into harbor freight and with some coupons managed to pick up the $299 blasting cabinet for $160 so I think I'll set that up this weekend, blast my manifolds and paint 'em. See how they turn out.
-- Joe
yeah doing a single with them but putting vbands right on the collectors so i can always go back to twins if i want
Next set will be a real turbo header on the drivers side, and a log on the passenger side with the same crossover. The log will more than handle my lower power goals.
You going with the vbands with the step in them I hope? Vbands are a MF if they arent perfect on the pressure side. I hate ever choosing them. Next setup is getting ball and socket hands down.
yeah the bands i ordered have th m/f steps in them hoping it all gets here by friday
so ive decided i really miss the lope and idle of the old supercharger cam , the cam in it now is really suited to a ported/aftermarket runner tpi build not the heads/hsr intake i have now
im thinking im going to go ahead and grab a
adv 303/303 @.050 234/234 .488/.488 114 lsa
or since i need to buy a new converter for the th350 anyways
adv 303/313 @.050 234/244 .487/.507 114 lsa
either cam will take be more suited to the heads and intake that are on this engine.
the second cam might be a lil much with the small housing on the 76 , but i dont need max power on the 76 , when i buy my 88mm i can size the hotside accordingly
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Oh Boy
I'm running a NX276HR cam and it's about as big as I want on this. Not a fan of lope.
-- Joe
lol maybe, street lethal knows me , i cant leave nothing alone, i cant even tell u how many changes i made to the turbo v6 car before i was happy with it.
and now that winter is here and im making the twin to single change + the trans change i cant help but changing so other things
the engine has to come out of the car anyway, ive got an oil pan leak, i used one of those nice one piece gaskets and when i put it on it didnt feel right but it looked like it sealed up.. well its leaking around the gasket , and im not fighting trying to pull the pan off in the car. so cam swap is just a lil more work
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
lol im hoping i finish all the changes by spring time so i can drive the wheels off this thing when the weather gets nice
this is all i acomplished today besides playing on the 4wheelers and dirtbikes in the snow on the farm todat
looking forward to more pics of this build as well.....my car is off to paint and then I will work on fine tuning the megasquirt and see if I can get rid of the pesky no start when I have a certain 2 wired connected.....then again I might just leave the timing locked out....
i gota take some pictures , got a package of parts today , the most expsensive lil package ever lmfao
2x 2.5 interlocking vband assemblies , and a 3inchn vband assembly , and 2x 50ftx2 inch black header wrap and an extra box clamps for it
all my new tubing was supposed to be here today but columbia river ****ed up my shipping adress so hpefully that will be here tommoroow
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What's the weather like in Utah? Negative temps here today. Horses are freezing, dog doesn't even want to go outside. I hate new england.
-- Joe
hopefully my order form columbia river mandrel bends shows up today
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
