Do I need a 2 bar MAP sensor?
Old Jun 23, 2014 | 08:04 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just installed a procharger D1SC on my car. Will the factory map sensor still work or do I need to upgrade to a 2 bar MAP sensor? Just need to know before I go to get it dyno tuned. I plan on running around 10 or 12 lbs of boost. Thanks
Old Jun 23, 2014 | 08:47 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Do I need a 2 bar MAP sensor?
If your using an FMU to supply fuel under boost, then no, you don't...
Old Jun 23, 2014 | 09:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am not using an fmu. Just getting my car tuned and using the 730 ecm.
Old Jun 23, 2014 | 09:48 PM
You would have to rewrite the code from scratch that way running an $8D bin. Best to run the $59 bin with either a 2 or 3-Bar MAP sensor, just set which sensor your going with and start tuning your fuel and spark tables through Tuner Pro . You can probably find a bin very close to your setup on the Code 59 website for a good base...
Old Jun 23, 2014 | 09:56 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I am not doing the work myself. It is all being done by the guy who is dyno tuned the car. What should I tell him to do then?
Old Jun 26, 2014 | 03:49 PM
Ronny's Avatar
Or run aftermarket ECU?????
Old Jun 26, 2014 | 05:04 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If he dont already know what needs done idk if he should be doing the tuning
Old Jun 26, 2014 | 06:12 PM
He seemed content with the 7730, otherwise I would recommend the EBL-P4 all the way. Justin makes a good point though, if the tuner was going to tune the 7730 just by slapping a 2-Bar MAP sensor onto it, he might not be the best tuner to go with...
Old Jun 26, 2014 | 06:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
If using code $59 you gotta have some background in it to know about what needs changed to make it run in a v8 and alot of base file work to build a file before starting car and tuning it. Not exactly simple, takes a few hrs of reading the information and downloading all the files and building the base tune to load. Unless hes done this before then its not a simple plug and play process. If its a procharger kit and you have a good na tune then use the fmu from procharger
Old Jun 26, 2014 | 07:54 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It is a procharger kit, but I didn't get the FMU. I only have a base tune done to the motor right now that was done by tunedperformance. Will I be able to get the car tuned with the blower and the factory 1 bar map sensor then?
Old Jun 26, 2014 | 08:22 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Your not going to get that thing tuned with a one bar map sensor. The sensor would be maxed and it has no way of telling the difference between naturally aspirated air and 12 psi. So your fuel and spark needs would be totally out of wack. Now I haven't seen it yet but with a 2 bar map you might be able to half the tables, still if it was that easy it would have been done already. Code $59 is a little to complicated for a beginner and would recommend staying away from it. Think your best option is go with the EBL-P4 and learn to do things yourself, I'm sure you would get a lot of help from people on here.
Old Jun 26, 2014 | 08:40 PM
Then simply buy an FMU from Vortech, as they offer an FMU kit with varying ratio plates to help you dial in your fueling. It is very easy to utilize...
http://www.vortechsuperchargers.com/page.php?id=30031
I only have a base tune done to the motor right now that was done by tunedperformance...
Again, find a bin close to your setup on the Code 59 website, reach out to Paul over there if need be. Or have Brian from Tuned Performance burn you a chip using the $8F mask as a base, he would just need to make the adjustments for the differences in the timing because your running a distributor, or simply go with the EBL-P4 like most of us did and be done with it.
Old Jun 26, 2014 | 08:53 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well you can kinda bandaid it with pe enrich vs rpm. Blower is more linear with boost vs rpm so it could get you close enough but reallly isnt optimal.
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
customblackbird
Oct 1, 2015 04:30 PM
87camaro87
Sep 9, 2015 10:29 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
