Anyone use the Racetronix dual pump kit?
Subscribe
Nov 25, 2014 | 07:47 AM
Okay I have done a dual 255 setup on my last car. I see racetronix has the dual 255 and dual 320's on sale. I was wondering if anyone used this setup before? and if it fits in the stock tank. Obviously there would be some rigging to hold them somehow.
Im only looking at this kit because I cant even buy the parts separate for this price and I really like the Y fitting.
http://www.racetronix.biz/itemdesc.a...PA-680&eq=&Tp=
Reply 0
Nov 25, 2014 | 04:53 PM
Re: Anyone use the Racetronix dual pump kit?
It will fit in the tank. I'm using a racetronix 340 and walbro 255 with the y fitting on a factory hanger. It works beautifully. Don't try to get by using the stock plug in the sending unit, a 340 will burn it up. I basically put a modified version of the Buick GN kit in.
Reply 0
Nov 25, 2014 | 05:04 PM
For my twin 340 setup I used the stock bulkhead harness.. In stock form, the ground is isolated through the bulkhead then connects to the hanger once inside the tank, so I used the ground wire as the power wire for the second pump. I added a ground lug to the top of the hanger assembly itself (using a small bolt with a bit of JB weld for seal and two nuts on top side) and grounded the second pump the remainder of the factory ground wire where it goes the tubing. I also didn't use the factory connector on the outside of the tank harness but made my own 4 pin weatherpack connector.
Reply 0
Nov 25, 2014 | 05:12 PM
I soldered an extra ground on my sending unit. I just didn't trust the factory intank wiring for that much current draw. The 340 draws around 12-14 amps at 14 volts. I figured I'd rewire it while I was there.... I don't want to drop the tank again lol.
Reply 0
Nov 26, 2014 | 04:59 AM
Awesome so it appears to fit. I may go that route. Just waiting on all these black friday deals before I buy anything. Plan on picking up the pumps and injectors and my speedhut gauges.
Thanks for that pic!
Also I plan on re-wiring all the fuel wiring and making my own "hotwire" Kit.
Jay
Reply 0
Nov 28, 2014 | 11:54 AM
I've looked at that assembly but thought that the 3/8 inch outlet at the top of the assembly kinds of defeats the purpose of running dual pumps, or am I wrong? Both pumps have 3/8 outlets y-ing into together into one 3/8 outlet.
Seems like it would be better to take those 3/8 outlets from each pump and run them to a -6 or -8 y outlet to feed the fuel feed line going to the front of the car.
It does look good though, if that means anything.
Reply 0
Nov 28, 2014 | 12:17 PM
Quote: I've looked at that assembly but thought that the 3/8 inch outlet at the top of the assembly kinds of defeats the purpose of running dual pumps, or am I wrong? Both pumps have 3/8 outlets y-ing into together into one 3/8 outlet.
No performance gain with independent outlets.
Reply 0
Dec 2, 2014 | 03:45 PM
Not sure if i understood that reply. So the billet aluminum dual pump holder has a 3/8 single outlet that is being feed by 2 3/8 pump outlets or is it a -6 single outlet?
Reply 0
Dec 2, 2014 | 04:14 PM
Quote: Not sure if i understood that reply. So the billet aluminum dual pump holder has a 3/8 single outlet that is being feed by 2 3/8 pump outlets or is it a -6 single outlet?
We are trying to emphasize the difference in size between a 255/340LPH pump's outlet stem and a -6 fitting. That being said our billet coupler will not impact the fuel delivery at all so there is nothing to be gained by larger or dedicated lines from each pump. We have customer's using our DPA-680 making over 1200RWHP!!! A -8 Teflon feed and -6 Teflon return are perfect for the DPA-680. -6 / -6 Teflon lines are fine for the DPA-510.
Hope that helps!
Reply 0
Dec 2, 2014 | 04:43 PM
The pump outlets are around 1/4 inch or so. The outlet of the coupler fits the factory sender. I cut off the part the pulse damper fits on
Reply 0
Dec 2, 2014 | 04:50 PM
Quote: The pump outlets are around 1/4 inch or so. The outlet of the coupler fits the factory sender. I cut off the part the pulse damper fits on
Yes, you must get rid of this tapered part of the metal line when using anything bigger than a 255LPH pump.
Reply 0
Dec 2, 2014 | 06:11 PM
Not to partially hijack the thread, but how did you get the dual pump in the hole? I have racetronixs' billet y piece and stand for the sender. Just cant physically get them in the hole. Do you have to put one in on the sender and then the other pump in the hole and then get it in place on the y and stand?
Reply 0
Dec 2, 2014 | 08:19 PM
It is very tight but it will fit. The float for the sender has to go in first. The pump mount is the hardest part to get in, but with a little persuasion it will go in.
Reply 0
Dec 3, 2014 | 05:40 AM
I ended up holding off on ordering this since their black friday deals didnt reflect the price. I think im going to go with the Dual 255's since they 320's draw a lot of amp's. I know when I did Dual 255's on my last iroc I had to position the pumps a few different times to get them to drop in proper. from what I hear the LS1 Plastic tank has a larger opening. I was gonna try to get one but to find one local is tough.
Jay
Reply 0
Dec 3, 2014 | 07:19 AM
Ok, good to know. Guess I will try again sometime over the winter. Thanks
Reply 0
Subscribe
