Fuel pump options
Old May 17, 2015 | 05:47 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
Fuel pump options
Im just curious if anyone has tried adapting the aeromotive phantom dual 340 to a factory tank. Seems like an easy way to get the needed fuel for my setup
Old May 18, 2015 | 06:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Fuel pump options
I know guys are getting 340's and 400's into 4th gen tanks as the opening is larger. It could be tight in a 3rd gen tank but with proper line size and injectors, that would be 1000-1200 whp fuel system depending on tranny
Old May 18, 2015 | 07:19 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Well the phantom series you cut the hole larger. And use their sending unit and everything. Id just have to get a different fuel level sender. I have to get a new tank anyhow. Ill look into a 4th gen tank and see what i can find on them
Old May 19, 2015 | 10:21 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Thanks for the heads up on the 4th gen tanks. Ive got one on the way. Im gonna do dual 340's with -8 line. That should be plenty for my small block and s480 combo with the 4l80
Old May 22, 2015 | 06:55 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
They swap in pretty easily. Just have to convert the 4 wire sensor off tank to the thirdgens 3 wire connector on the body. Need a grand am sending unit from mid 1990's i think. I just finished my second 4th gen tank swap lol i forget the part numbers already.
Then just need the plastic type AN conversion quick disconnects and its ready to go
Old May 22, 2015 | 08:13 AM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Im venturing into aftermarket efi. MS3 so im not 100% sure if ill have to wire it up seperatly anyhow. Ill get it figured out
Old May 22, 2015 | 01:51 PM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Dual 340LPH Racetronix units fit with relative ease in the 4th gen fuel tank sending unit. You will want the additional capacity if making serious power anyways. I used a -8 bulkhead 90° and I used the stock feed as a return. I trimmed out the factory return port and plugged the hole with seal-all. I decided to do away with the wiring bulkhead as the contacts were pretty small anyways. I passed the wires through where the tank pressure sensor was installed, and I sealed it with a combination of seal-all and shrink wrap.
Attached Thumbnails Fuel pump options-20140528_224454.jpg   Fuel pump options-20140528_230921.jpg   Fuel pump options-20140528_230904.jpg   Fuel pump options-20140530_205831.jpg   Fuel pump options-20140807_201643.jpg
Old May 22, 2015 | 11:15 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
Very nice. Im gonna run the 2nd pump off a hobbs switch. I have a long way to go. But ill get it.
Old Jun 25, 2015 | 12:24 PM
vortec350s10's Avatar
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
I remember reading about the 4th gen tank swap, do they really bolt right in? What about the filler neck? I'm running a single Stealth 340 pump with -8an feed and return and am running out of fuel at 12psi on E-85. I know fitting a second pump can be a pain in a 3rd gen tank, so just weighing the options.
Old Jun 25, 2015 | 01:32 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
They bolt in but you need to shorten the filler neck hose they come with by about 1.5-2" or so. Work great.
Then gotta connect the 4 wire tank harness connector to the thirdgen 3 wire body plug. These adapters can be bought from racetronix
You need a sending unit for thirdgen gauge. Believe its just a 97 grand am unit for 80-100$ i think. Have to check my last rockauto purchase for that. Plugs right in
Old Jun 25, 2015 | 09:11 PM
Car: '88 Iroc
Cool thanks Justin. I might just have to try that if I get frustrated with changing around my third gen tank a second time.
Old Jun 25, 2015 | 09:47 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
I found mine complete with fuel pump and sending unit for 99 plus shipping
Old Jun 26, 2015 | 09:11 PM
LC2 TECH's Avatar
Had not plan on revealing this till we were a little further along but we a working on a new double pump setup for Thirdgens. We will also be doing a single pump version. Will work with -an or stock fuel line and they will come with a hot wire kits.
The creator of these has done a couple of double pumper setups based on stock hanger setups for some TTA's we have built in the past but these will be all new. This is the Gbody version.
Old Jul 3, 2015 | 10:40 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Nice looking set up, when do you think the double pump setup for Thirdgens will be released?
Old Jul 4, 2015 | 10:43 AM
LC2 TECH's Avatar
I hope to have the prototype done this month and installed for testing. So by the end of summer is the current schedule.
Old Jul 4, 2015 | 10:21 PM
83 Crossfire TA's Avatar
What's the point of putting the stock filter socks inside the bucket if you've removed the stock venturi pump? Might as well stuck them through the bottom of the bucket in the location of the fuel sock pickup for the venturi pump.
They pretty much bolt in, you need to shorten or replace the filler neck hose from the 4th gen tank (most junkyards will cut them so you'll need to replace it), bend the mouning bracket slightly and screw it to the pinch seam in the 3rd gen to support it. Past that you need to adapt the plumbing which isn't that big a deal and the wiring/fuel level sender
Old Jul 7, 2016 | 12:44 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Whatever happened with this? Can they be purchased?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
