Procharged 383 TPI Dyno Numbers
Old Aug 8, 2015 | 08:05 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just had my procharged 383 TPI (specs in sig) dynoed. The car made 521 rwhp and 583 rwtq. Peak numbers with the blower making 7 lbs of boost. Much thanks on here to Orr89RocZ and the guys at FJ Performance for helping finally get this set up tuned correctly.
Old Aug 8, 2015 | 09:54 PM
-=Z28=-'s Avatar
Car: 84 Z28
Engine: 383 Stroker
Re: Procharged 383 TPI Dyno Numbers
Those are some pretty nice numbers! Congrats.
Whats it feel like to watch someone else put your car to its limits to see what shes got??
Old Aug 9, 2015 | 06:48 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
It was definitely interesting. I was happy with the results. I guess sooner or later i'll have to see how it responds to 12 lbs.
Old Aug 9, 2015 | 07:53 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
whats it tuned with?
Old Aug 9, 2015 | 09:40 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Glad you are happy with it. Stout car for sure! Torque band is insane
Old Aug 9, 2015 | 11:18 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I'm running the ebl p4 ecm, which I got from dynamic efi. Member Rbob on here designed that whole ecm set up I believe.
Old Aug 10, 2015 | 04:56 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Nice tq numbers! Gotta feel nice on the street. Main reason I miss my old 383 LT1 over the LS stuff.
Jay
Old Aug 10, 2015 | 10:08 AM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
AWESOME numbers man. Very stout for the boost. Turn it up to 12 already
Old Aug 10, 2015 | 10:32 AM
rb85TA's Avatar
Car: BUILDING 1985 HARD TOP T/A
Engine: sbc
Transmission: stick
Axle/Gears: GM
I'm waiting to see the 14lbs boost #'s ☺
Old Aug 10, 2015 | 10:50 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
This thing off the hit at 2500 rpm was already making 450 wtq and seeing 1-2 psi boost. Still over 540 lb ft at 5000 where run was cut short as it was having issues keeping blower belt on. It will make 12 psi by 6000 but tpi is hurting power production at that point.
Old Aug 10, 2015 | 03:55 PM
rb85TA's Avatar
Engine: sbc
Transmission: stick
Axle/Gears: GM
Yeah, not the greatest intake for that setup, have you thought about running a mini-ram?
Old Aug 10, 2015 | 04:14 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yes, it will be suffering from the TPI wall. There really is no way around it, it seems.
Why do you think it's having belt issues? Is it flex or alignment?
Old Aug 10, 2015 | 04:31 PM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Get a MAX-ported tpi. I did, and I have to rev it into 5000rpm+ range...or I LOOSE e.t AND mph.
https://www.thirdgen.org/forums/engi...-full-tpi.html
Old Aug 10, 2015 | 05:03 PM
rb85TA's Avatar
Engine: sbc
Transmission: stick
Axle/Gears: GM
Does the cost of the "MAX TPI" compare to, or is it less than a mini-ram?
Old Aug 10, 2015 | 06:27 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
The car already has a welded up and ported base. Not a whole lot left to do there except shorten the runners.
I'll try to get a copy of the dyno chart but as tpi falls off naturally from long runners, the procharger is making more and more boost. That boost is adding back power to offset the tpi shortfall. Result is table top flat hp and torque curve. That thing will still make alittle more power peak beyond 5k but not a ton more. But it does extend to 6k and likely beyond but i only took it to 6000. Very impressive curve tho.
Old Aug 10, 2015 | 06:54 PM
rb85TA's Avatar
Engine: sbc
Transmission: stick
Axle/Gears: GM
Just drive the **** outta it! It's making enough at the wheels to have fun in & really **** off some snobs ��
Old Aug 12, 2015 | 01:30 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Got a vid of it running!? What a beast
Old Aug 12, 2015 | 07:56 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
are you running a forged bottom end?
Old Aug 13, 2015 | 01:58 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yes the car has an eagle forged bottom end. Unfortunately, I don't have any videos of it running. I think it is an alignment issue that's making it throw belts. I'll have to check more into it when I get some free time.
1992rs/ss
Jan 31, 2025 05:10 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1984HO
Mar 19, 2021 11:59 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
