Injectors
Old Aug 1, 2019 | 02:43 PM
Mattroth's Avatar
Injectors
Hello guys just wondering what are some good after market injectors recommend size?
currently what is done to car
350 bored .30 over
Engle Chevy 350 4bolt main 87 block
Bored .30 over
Eagle rotationing assembly kit
Keith black flat top hypertonic pistons
1.5 comp roller rockers
Comp cams 490lift
Dart aluminum cylinder heads 127122
stock intake and injectors and tpi
Old Aug 1, 2019 | 02:53 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Injectors
Southbay Bosch 3s
Old Aug 1, 2019 | 03:13 PM
Abubaca's Avatar
Re: Injectors
Yup. Contact Southbay. They a sponsor. Logo/Link is right over there, lol >>>>>>
22# or 24# would be all you really need. Ideally 22# if you're on a stock tune, but countless people have had zero issues with 24's on the stock tune. Myself included.
Old Aug 1, 2019 | 03:19 PM
Mattroth's Avatar
Re: Injectors
So I’m going to get the car tuned so would 24s be better or 22 still good do know what the stock size is thanks for all the help
Old Aug 1, 2019 | 03:21 PM
Engine: Lb9
Transmission: M20
Re: Injectors
Stock 350 is 22#hr
Old Aug 1, 2019 | 03:23 PM
Mattroth's Avatar
Re: Injectors
Ok so 24s probably my best bet when tuned?
Old Aug 2, 2019 | 12:15 AM
no new tires's Avatar
Car: 88 IROC-Z
Engine: GEN 4 LY6 (going forged 408)
Transmission: 60E (going RPM LEVEL 6 4L80E)
Axle/Gears: 7.5" 3.42 (staying...)
Re: Injectors
Originally Posted by Mattroth
Ok so 24s
SouthBay 24s for sale here
https://www.thirdgen.org/forums/engi...hbay-24-a.html
Old Aug 2, 2019 | 07:25 AM
Abubaca's Avatar
Re: Injectors
So stock injectors are 22# for the L98/350. If you change that, but not the tune, the computer won't be signaling the injectors to open for the right amount of time. With 24#, being larger than stock, you'll be injecting more fuel with every injection. Vice versa if you went smaller than 22#. But as I mentioned earlier, the difference between 22# and 24# is so minimal, it's likely to not cause any issues. Many many people have run 24# without having it tuned and never seen any negative effects. Still, to do it properly, you need to tune for any change. If ya wanna get REALLY deep, even 22# injectors made by different companies flow differently, and should "technically" be tuned for....but don't even worry about that.
...Since you ARE going to have it tuned though, it really doesn't matter which you choose, as the different sizes can/will be accounted for in the tune. If you choose a larger injector, the injector will just fire for a shorter period of time because it's injecting more fuel. If you choose smaller, it'll just stay open longer. Either the 22 or 24 will be MORE than suitable for your application.
Old Aug 2, 2019 | 10:38 AM
southbay08's Avatar
Re: Injectors
thanks guys. Yes give us a call and we'll be more than happy to help you.
516-442-4707
Old Aug 2, 2019 | 12:19 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Injectors
Any plans to upgrade tpi? 24 lb should cover that. Good heads but not good intake so it will be restricted some in power. A better intake and cam you could get up to the max end of 24’s easily
TBI89Formula
Sep 13, 2002 10:40 AM
JR4444
Feb 13, 2002 09:03 AM
86TransAmTPI
Sep 20, 2001 02:59 PM
WSU
Sep 17, 2001 11:24 PM
88Roc350TPI
Jun 2, 2001 05:07 PM
