Procharger air intake help
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
Where can I find a Procharger 45* elbow for air filter? I'm almost finished with the install and can't seem to find one. Any help is appreciated fellas. Thanks.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Procharger air intake help
Do you need a Procharger specific elbow, or any elbow that would match your setup?
- Rob
Edit: I buy from the below all the time, so I will vouch for them in terms of checkout security...
http://www.siliconeintakes.com/alumi...ipe-p-286.html (3")
http://www.siliconeintakes.com/alumi...ipe-p-288.html (4")
- Rob
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Check with brutespeed maybe? Procharger dealers
https://shop.brutespeed.com/ProCharg...550.htm?page=2
Thanks fellas. I will check them out later today. Slowly working finishing up my ProCharger install since I ditched the turbos.
Car: 89 WS6 TransAm
Engine: LQ408
Transmission: T56 Magnum
Axle/Gears: Strange S60, 4.10s
I used a 90 silicone hose and cut it to the required angle. Provided a nice tight bend right at the SC. Of course you only have one attempt so be accurate. Then extended the 4” tubing as high as possible to let the filter pickup some cooler air from back of hood. Definitely not ideal, but is functional.
Car: 89 WS6 TransAm
Engine: LQ408
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Car: 88 GTA, 74 T/A
Engine: 383 stroker (Procharged)
Transmission: TH400 w/brake (new 2013)
Axle/Gears: 12-Bolt S60 - 3.73 (new 2013)
This is my air intake system, wanted to avoid pulling in all the header heat by adding an extension pipe.
