Bov
Old Mar 14, 2002 | 11:31 PM
PimpCamaroRS's Avatar
Bov
hey guys i am kinda new to the Power Adder board but have tried researching but with no luck. I am trying to find out sme info on Blow Out Valves. I prety much know nothing about them. all i knwo is that my friends mustang has them an when he shifts and it make that sound i love it!!!!!! I have an automatic tho, does it make a difference? thanx alot guys
Old Mar 15, 2002 | 09:38 AM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
I'm not real sure on the specifics of blow off valve operations but here goes.....
A blow off valve is a valve that when under vacuum is open. When boost builds the valve closes and allows everything to work as normal. When you let off the gas suddenly (like when driving a stick) the throttle plate closes and all that air from the turbo has nowhere to go. The bov opens and allows the air from the turbo to escape. If the bov wasn't there all the air would bounce off the closed throttle plate, come back and stall the compressor or worse. Cars with auto's don't need these as bad as manual cars do. With manuals you'd kill boost between shifts without one, but with autos since you never let up they do fine. Someone else will probably give a better explanation.
Old Mar 15, 2002 | 09:42 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
click on the search key in your upper right hand side of this screen, pick the power adder section, and type in BOV or blow off valve and watch your computer explode.
Old Mar 15, 2002 | 12:27 PM
do you only use blow off valves for turbo chargers or is it fo super chargers too......basically what is the difference(price and HP gains ould help too)
Old Mar 17, 2002 | 08:07 PM
so does any one wanna tell me the difference between turbo charge and super charge? I think one used air from intake and one use's exhaust air but i am not sure. Which one is easier to install and which one is CHEAPER ?thanx
Old Mar 17, 2002 | 08:47 PM
Car: 86 Cutlass
Are you asking for the difference between a turbocharger and a supercharger? First off, do some research. Go to howstuffworks.com and check these things out. Search the board. Search on yahoo. Just research, you'll learn a lot.
Now that thats outta the way.......
A turbocharger is a turbine driven by exhaust gases. A supercharger is belt driven.
Old Mar 18, 2002 | 10:06 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
go to amazon dot com and look up books on both.
Old Mar 18, 2002 | 04:14 PM
rhuarc30's Avatar
Ok, you can use bov on superchargers and turbochargers, you don't really need one til your boost gets above a certain level. A supercharge will be far easier and cheaper to install, turbo's can offer a much higher performance level. And Finally a supercharger is driven by a belt off the crank and a turbocharger is driven by exhaust gasses. Other than that check out the books they reccomended.
Terrell351
Jun 13, 2021 01:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Wife'sCar
Sep 5, 2015 08:58 AM
junkcltr
Jul 22, 2005 11:35 PM
