power chips, a good idea?
Old Mar 31, 2002 | 08:05 PM
5.7L OF JUSTICE's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7L TPI
I have a 87 IROC with the 5.7L TPI engine. I was wondering if a power chip is a good idea with this car. What kind of power increase will I be looking at? How much money will I be looking at? What kind do you recomend getting? Any comments will be helpfull.
Old Mar 31, 2002 | 11:03 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
HP= 5 MAYBE
Money= About $170 (hyperjunk)
Worth it? Hell no. It was the bigggest waste of money I have spent. Advance the timing a bit and put a cooler thermostat in and you just did basically all the chip will do.
Old Apr 2, 2002 | 11:12 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I picked up .5 sec and 3mph with a $70 SLP chip, my car had headers,exhaust, CAI, 160 stat, the SLP chip dropped my coolant temps 20* to 200*, don't know if it helps as much on a car with stock exhaust.
The SLP chip beat my stock chip by .7 sec and 6 mph with above mods and a cam, 1.6 RR, and siamesed base.
I wouldn't get a hyperjunk or Jet chip though, try fastchips(ed Wright) I heard they're usually worth the money.
Old Apr 2, 2002 | 02:32 PM
Vroom's Avatar
Instead of buying a power chip, let me do this.
Give me 170$.
I will raise your fuel pressure 2 PSI, and advance your timing.
I will then kick you square in the nuts, giving you everything and more that an off the shelf "performance" chip will.
Old Apr 2, 2002 | 08:34 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Give me 170$.
That sounds like a good deal, can I get in on some of that too? :sillylol:
Rob
Old Apr 2, 2002 | 10:45 PM
Rob
Im running a special on that package... 149.99, but for a limited time only, while supplies last!
Old Apr 3, 2002 | 03:40 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Do you still get the kick in the nuts with your package? I'm wanting as much as possible for my money. :sillylol:
Old Apr 3, 2002 | 09:41 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
hypertech stage II thermomaster = .2 seconds off E.T., solid control arms w/heimjoints = .45 seconds off E.T. best ever in 1982 camaro with 1985 305 TPI swap 14.5
Old Apr 5, 2002 | 09:15 AM
92superram's Avatar
Aftermarket chips are only good if your engine is heavily modified.
Mine runs like **** with the stock chip.
jaridjohn
Jul 8, 2024 03:49 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
NBrehm
Aug 25, 2015 11:49 PM
InfinityShade
Aug 22, 2015 08:00 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
