Problems / Help / Suggestions / Comments Let us know if you're having any problems with the site or board software. Post any ideas you might have for ThirdGen.Org here.
Need some help...
Old Jun 8, 2003 | 02:05 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Need some help...
Ok how do I put pictures into posts without having to attach them? I tried the IMG button above but all that did is create links. I have the pictures uploaded to car domain and would like them to show up like attachments without taking up the server bandwidth.
Old Jun 8, 2003 | 02:42 AM
joshp14's Avatar
go the the picture at cardomain and right click on it. then go to properties...then highlight the URL and paste that link in the IMG button. Then it should work.
Just to see if the cardomain images will work...
Old Jun 8, 2003 | 01:39 PM
trans87's Avatar
O ok. So I guess you just can't use the full size pictures then?
Old Jun 8, 2003 | 01:58 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
You can use whatever size pictures you have uploaded to your Cardomain site. I'm not sure if they have a limit.
Old Jun 8, 2003 | 04:40 PM
trans87's Avatar
Ok I see now you just can't put more than one pic per post. I was putting multiple images in one post
Old Jun 8, 2003 | 05:11 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You can put more than 1 per post if they're linked,least you used to be able to.
Old Jun 8, 2003 | 09:03 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
you should be able to link up to 8 photos per post by using the img tags..
Old Jun 8, 2003 | 10:26 PM
trans87's Avatar
Ok cool. Yea I figured out how to do it now. I was doing everything half *** backwards lol Thanks for your guys help, you pointed me in the right direction
Old Jun 9, 2003 | 04:31 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
not a problem, that's what we're here for!
Zane Story
Oct 8, 2015 12:40 PM
R13_Braz
Sep 18, 2015 05:00 PM
Kj Rockz
Jan 6, 2002 06:00 AM
Locry
Apr 29, 2001 12:09 PM
98_1LE
Mar 1, 2001 12:44 AM
